Author Topic: Would this make much difference in small clubs??  (Read 892 times)
Debbie Dunkley
  • Central North Carolina
« on: May 28, 2023, 10:13:42 AM »
I run my Danley system mono subs but I've never worried too much about the small powered system -  I usually run the subs in stereo. One each side of the stage with tops above - makes set up and wiring fast. My stereo settings are very subtle - panning is not far from center on any channel - but I use it mainly to separate instruments slightly. I have done things this way for many years. Sometimes I couple the subs when I can.
However, I'm going to start using mono in the subs to see if I can hear much difference in these smaller places....
My question is this: Is the result the same whether I  1) send L & R from the mixer to a sub Ch1 and Ch2 and allow the sub to sum the inputs OR 2) send a combined L & R to sum mono before it hits the sub inputs. ??
Bob Stone
Re: Would this make much difference in small clubs??
« Reply #1 on: May 28, 2023, 10:39:49 AM »
Assuming the overall sub level stays the same and the mono-summing circuit/algorithm is the same, then shouldn't make a difference.
I have found if I send stereo to the sub and let it mono sum, rather than just sending it a single mono signal, the output level does increase with the sum of those signals. In other words, have one signal at say -10db going to the sub, plug a second signal at -10db going to the sub, and you pick up ~3db.
Debbie Dunkley
« Reply #2 on: May 28, 2023, 11:14:30 AM »
Thanks Bob - the potential increase in level did occur to me. This is not  my goal but I'd need to keep in mind when I set the levels.
Helge A Bentsen
  • Oslo, Norway.
« Reply #3 on: May 28, 2023, 01:09:25 PM »
Should be the same. Expect a 6dB level increase when you sum down two channels.
I like to do this in the system DSP so it can be quickly reconfigured if I have guest mixers.
Bob Stone
« Reply #4 on: May 28, 2023, 06:00:30 PM »
Shouldn't it just be 3db?
Frank Koenig
  • Palo Alto, CA USA
« Reply #5 on: May 28, 2023, 11:06:30 PM »
When two signals of the same average power are summed the resulting signal is between 3 and 6 dB greater. In one extreme, if the signals are perfectly correlated (the same signal), the voltage, current, sound pressure or volume velocity sum (coherently) to result in a 6 dB increase. If the signals are uncorrelated the power sums to result in a 3 dB increase. If there is partial correlation, say the channels of a stereo program where there is considerable overlap, the result is somewhere in between.
This is the basis of signal averaging where adding multiple segments of a signal in such a way that the desired part is correlated and the noise is uncorrelated results in an increase of signal-to-noise of sqrt(N) where N is the number of segments.
--Frank
John Schalk
« Reply #6 on: May 29, 2023, 07:57:50 AM »
Thanks for this explanation.  I had noticed this result recently when sending L+R to a single matrix output.  I was expecting more level and thinking it would be +6dB, but it was closer to +3dB using recorded music as the signal.
Page created in 0.042 seconds with 22 queries.
