Author Topic: X32 mutes and AES  (Read 116 times)
Mattijs Bosveld
X32 mutes and AES
« on: May 24, 2023, 06:08:52 AM »
Hi guys,
In a setup with a WING for FOH and X32 rack for monitoring:
Is there a way to set it up so the mutes on the X32 rack will also mute the channel on FOH? connected via AES50.
Hope to hear from you
Brian Jojade
Re: X32 mutes and AES
« Reply #1 on: May 24, 2023, 10:02:24 AM »
You can set up the 'user out' to pick from output or ultranet channels or aux output channels which can be assigned different tap points. Then route the user out to the AES50 port.
Outputs and Ultranet channels are limited to 16 each and 6 aux channels, so you can sort of achieve what you want, but with limitation.
« Last Edit: May 24, 2023, 10:19:53 AM by Brian Jojade »
Brian Jojade
Page created in 0.063 seconds with 19 queries.
