Author Topic: Tiny washers for Shure Ulx antennas  (Read 557 times)
Michael Mills
« on: March 19, 2023, 09:25:09 AM »
Apparently the rack mount of this unit was rushed, and the antenna washers were misplaced or lost. Now the front mounted antennas are, well,... for lack of a better word, all floppy cocked.
Where can these washers be acquired or does anyone know which size o rings are appropriate.
Henry Cohen
  • Westchester Co., NY, USA
Re: Tiny washers for Shure Ulx antennas
« Reply #1 on: March 19, 2023, 01:08:31 PM »
7/16" ID rubber O-ring. May need two per connector depending on length of connector body.
Henry Cohen
Michael Mills
« Reply #2 on: March 20, 2023, 09:19:43 PM »
7/16 seems a bit large to go inside a bnc connector
Michael Mills
« Reply #3 on: March 20, 2023, 09:27:47 PM »
Let me clarify.
BNC bulkhead connector on front of rackmounts.
Antennas will not stay upright.
Bulhead connector is not the issue, from my research I see very small rubber o rings that go inside bnc on bulkhead connector.
Inquiring as to what size this o ring is and its thickness and.where can I acquire the shure o rings as the ones I have found are too thin and compress too much, or too thick and difficult to compress.
« Last Edit: March 20, 2023, 09:30:32 PM by Michael Mills »
« Reply #4 on: March 21, 2023, 10:02:15 AM »
What did Shure say when you called them?
"Art has always held a tenuous position between acts of subversion and status symbol collected by those who profit from the very status quo the art purports to subvert." - Stephen Colbert
Michael Mills
« Reply #5 on: March 22, 2023, 05:11:28 AM »
I emailed shure, awaiting reply.
Shure states that these are not actually O rings but flat rubber washers..
These measure. 8 mm OD.  4.5 mm ID  1 mm thick
Sent what I needed right away. Thanks all for your help
« Last Edit: March 23, 2023, 01:53:01 AM by Michael Mills »
Page created in 0.051 seconds with 21 queries.
