Author Topic: DSP setting Ashly protea  (Read 1767 times)
Jan Chr
« on: January 27, 2023, 05:52:52 AM »
Hi!
Is there anyone out there who Can help me with DSP setting for Ashley protea to Community SLS 960
David Simpson
Re: DSP setting Ashly protea
« Reply #1 on: January 27, 2023, 11:35:52 AM »
I am guessing you are looking for crossover points? Here is a link to the manufacturers data sheet that includes those as well as other important data.
https://downloads.biamp.com/assets/docs/default-source/discontinued/biamp_data_sheets_community_sls960_jun21.pdf?sfvrsn=cf5391c4_6
~Dave
Jan Chr
Re: DSP setting or EQ Ashly protea
« Reply #2 on: January 30, 2023, 11:38:33 AM »
Hi!
I try again.
This I use in my Drivrack.
For Community SLS 960
Hpf: 110hz, 4th order LR
EQ:
1: 251hz,-5, .33BW
2: 508hz, -5 .5,41BW
3: 2,45k,-4,5.52BW
4: 3k,-3, .39BW
5: 4,5k, -6 .3BW
6: 9,6k,+6 1.58BW
Is this setting correct?
Can anybody out here tell me?
Or give me the correct setting.
« Last Edit: January 30, 2023, 12:41:12 PM by Jan Chr »
Dan Richardson
  • southern Vermont
    • NotTooLoud
« Reply #3 on: January 31, 2023, 10:14:27 AM »
Do those settings sound good in your application? Use them as a starting point. Nobody can give you "correct settings" without hearing the system in place.
The best sound system is no sound system. Everything else is compromise.
Mike Caldwell
  • Covington, Ohio
« Reply #4 on: January 31, 2023, 01:25:40 PM »
Also are you planning on running them passive or bi-amped, that would make a BIG difference on the settings.
Are you looking just for the settings and or someone to program the unit?
Jan Chr
« Reply #5 on: February 01, 2023, 11:32:05 AM »
Just for the settings.
Page created in 0.063 seconds with 19 queries.
