Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Installed Sound/Contracting
M10 bolts vs eyebolts
(1/1)
Bradford "BJ" James:
The Yamaha BWS251 instructions indicate to use M10 bolts as pictured …..supposedly provided with the speakers (but not). I’m not seeing a lot of options for hex head fly rated M10 bolts. Thinking shouldered eyebolts would do the trick (plus provide a easy spot for a safety cable). Any issues using eyebolts here?
Yamaha has not got back to me yet.
Thanks.
Craig Hauber:
--- Quote from: Bradford "BJ" James on January 26, 2023, 01:41:11 PM ---The Yamaha BWS251 instructions indicate to use M10 bolts as pictured …..supposedly provided with the speakers (but not). I’m not seeing a lot of options for hex head fly rated M10 bolts. Thinking shouldered eyebolts would do the trick (plus provide a easy spot for a safety cable). Any issues using eyebolts here?
Thanks.
--- End quote ---
I prefer not to guess or assume when it comes to overhead suspension. Staying within the exact manufacturer spec just makes things easier.
Call the people at Full Compass in Wisconsin, they have tons of specific repair and replacement parts for most all pro audio manufacturers, they can probably get you the exact Yamaha-sourced part.
Brian Jojade:
Well, the instructions in the photo clearly say use the bolts that come with the speaker...
But really, I wouldn't overthink this too much. This unit has a load rating of 66lbs. You could probably put nylon bolts in there and never have them fail.
Dave Garoutte:
--- Quote from: Brian Jojade on January 26, 2023, 03:05:25 PM ---Well, the instructions in the photo clearly say use the bolts that come with the speaker...
--- End quote ---
Agreed, even a junk bolt is going to have tensile strength in the thousands on pounds.
If you want something known, McMaster Carr has everything, in stock. Here in CA, delivered next day.
Mike Caldwell:
Any grade 5 or higher is going be way more than needed. Are there any other points for a safety eyebolt?
Check the depth of the threaded insert, so you don't bottom out the bolt.
Navigation
[0] Message Index
Go to full version
