Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Lighting Forum
Power draw / Daisy Chaining
<< < (2/3) > >>
Debbie Dunkley:
--- Quote from: Erik Jerde on January 16, 2023, 03:45:37 PM ---They only give the must be same type thing because that way they're in a better position when someone does something stupid like putting a coffee maker on the end of the chain and starting a fire.  Power is power, the fixture won't care what's plugged into it as long as you don't exceed it's ability to pass through power.
Doing the math you get the following for max load through a given fixture:
1) 7.68A
2) 4A
3) 5.2A
That's by taking the max fixtures in a chain, remove one (because the we're finding the load that is passed through) and then multiply.  For the first this is (13-1)*.64A.
Once you look past the CYA lawyer stuff it's like most power stuff where you just have to do the math.  It's entirely possible that with staggered startup you could run more on a chain but they need to be careful of stuff like inrush current when you power up a whole chain at once.  I'd just go with what you can deduce from the manual.
--- End quote ---
Cool - thanks Erik. Makes sense. I am no where near the max then so should be good to go!!
Brian Jojade:
--- Quote from: Debbie Dunkley on January 16, 2023, 04:03:06 PM ---Cool - thanks Erik. Makes sense. I am no where near the max then so should be good to go!!
--- End quote ---
With LED lights, it's awesome that you can pass power through. With my first LED cans, I actually modded them and added edison plugs on the back, wondering why nobody offered that as an option at the time.  With the stock 18 gauge power cables, you could string lots of lights together with no issue.
Debbie Dunkley:
--- Quote from: Brian Jojade on January 16, 2023, 06:11:34 PM ---With LED lights, it's awesome that you can pass power through. With my first LED cans, I actually modded them and added edison plugs on the back, wondering why nobody offered that as an option at the time.  With the stock 18 gauge power cables, you could string lots of lights together with no issue.
--- End quote ---
Yes, it makes wiring trussing so much easier…
Dave Garoutte:
--- Quote from: Debbie Dunkley on January 16, 2023, 06:45:18 PM ---Yes, it makes wiring trussing so much easier…
--- End quote ---
And you can get shorter and longer IEC cords to use exactly your needs, even cleaner on standard setups.
Debbie Dunkley:
--- Quote from: Dave Garoutte on January 16, 2023, 06:55:12 PM ---And you can get shorter and longer IEC cords to use exactly your needs, even cleaner on standard setups.
--- End quote ---
Yes I try to keep them neat by customizing lengths. I usually make them to size if I cant find what I want stock.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
