Author Topic: I-Mag suggestions  (Read 1256 times)
Craig Hauber
I-Mag suggestions
« on: January 12, 2023, 12:12:28 PM »
Looking to eliminate the 1694a coax runs thru the audience areas for I-Mag cams on a tour.
Are any of the network video formats of low enough delay to use for live I-Mag (of a musical show with choreography). I hate shooting active performers when the results appear on screen almost a whole bar behind the live! (and this has been a battle with our current cams/coax/ATEM/projector setup)
And if so, what type of network bandwidth would I need for 3 x 1080 feeds?
I have a 10G fiber link between stage and FOH that my Control, DMX and Dante is barely using.
Because we set up in a hurry daily I would love less lines than the 250' hod of coax we currently figure-8 into a trunk and instead move everything to a lightweight fiber on a spool.
(Just another episode of a sound guy having to solve everyone else's problems.)
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Dave Garoutte
  • San Rafael, CA
Re: I-Mag suggestions
« Reply #1 on: January 12, 2023, 01:50:45 PM »
There is inherent latency in HDMI.  Different cameras can have from 2-8 frames of lag to the output.  Any converter will add more.
You might look into NDI for vid over ethernet.  I don't know their latency.
I have some Hollyland Cosmo 600 wireless Tx /Rx that have almost no latency.  Between the BMCP4k and that, I can stream 1080 live handheld music in near real time.  No cables.
« Last Edit: January 12, 2023, 01:53:11 PM by Dave Garoutte »
Erik Jerde
« Reply #2 on: January 13, 2023, 02:00:23 PM »
If your goal is just to get to fiber because it’s less bulky/easier to work with then use SDI copper to fiber converters and be done.  I’d stick with SDI.  There’s a reason why it’s been the professional video transport for years.
Craig Hauber
« Reply #3 on: January 18, 2023, 05:21:36 PM »
Yes I have been discovering that in my research.  SDI on coax is still the transport medium that provides the highest bandwidth for the least cost.
Also found that 12-strand SM fiber on a spool is surprisingly affordable. Even considering I may have to carry an identical spare because it is definitely an "all eggs in one basket" type situation.
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Erik Jerde
« Reply #4 on: January 19, 2023, 09:12:25 AM »
The fiber you’re referring to is probably MPO terminated fiber that you can put breakout whips on.  It can be surprisingly cheap.  I just got 2 30M MPO MM cables for $48 bucks each.  Helluva deal.
I’d strongly caution you against using fiber intended for data centers though.  I’d be concerned about durability in a live production environment.  Most video fiber that I’ve worked with is heavier duty tactical type cable terminated with neutrik opticon which is a ruggedized LC fiber connector intended for the type of work and environments we encounter.  You’re also much more likely to be able to find rentals.
Craig Hauber
« Reply #5 on: January 20, 2023, 09:25:04 PM »
I was looking at 500' tactical grade field deployable vehicle drive-over rated 12-strand LC-LC SM.
Technically not "cheap" but still inexpensive compared to the cost of the gear plugged into it!
I'm still finding that just sticking with 1694 coax is still cheaper if not a bit more time consuming and awkward to deploy.
Still searching for low-latency cameras, The PTZ optics cams are way worse than the newer JVC 4k camcorder  -It's actually tolerable.
But also in design talks with production to revisit the set design.  If we can get it so the I-Mag isn't upstage but off to the sides then people wouldn't be able to see live and on-screen simultaneously (as easily).
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Page created in 0.026 seconds with 20 queries.
