Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Lighting Forum
Light tree case??
Kevin_Tisdall:
--- Quote from: Mike Monte on December 10, 2022, 07:31:11 AM ---I have made the jump from par38 cans to LED lights...
The above being said, I now need to transport them to/from gigs without dinging-them-up.
I have bags that I have used for years with my par cans but would like to get something a bit more sturdy as the LED mounting brackets are not as robust as par can brackets.
Specifically: I want to leave the lights permanently attached to the crossbar. Once a gig has ended, remove the crossbar fro the top of the light stand and place the bar (with lights attached) in a case.
I have four lights attached to each crossbar.)
I am not looking for road-worthy cases as I only do local stuff..... Maybe something SKB'ish or similar.
I've done some searching online and have come up short...
Any recommendations.
--- End quote ---
I got two assemble-yourself wood road cases for just this purpose. Odessey tree tops with 4 led pars hanging, power strip, and wireless receivers connected. I put in "bulkheads" so the bar is supported and the bar just drops into those supports. With cover on the case the bar cant move. I move with a hand truck /cart but could install casters now that i move things in a trailer vs pickup truck.
--Kevin
Mike Monte:
--- End quote ---
After much re-searching (& deciding what I wanted) & then searching, I found a used Gator GTSA-Key88 TSA case for $200 on my local Marketplace.
Both trees fit in there nicely.
I am in the process of cobbling together foam blocks to cut and glue in there to secure the lights so that the frames won't bend when the case is inverted/moved.
It will probably look a little "franken-case" with a combo of black/gray/white foam when I'm done with it but I don't plan to enter it in a beauty contest - lol.
I could purchase sections of real foam to customize the case but why go through the added expense.....plus it's best to recycle when possible.
Thanks for all of the suggestions.
Navigation
[0] Message Index
[*] Previous page
Go to full version
