Author Topic: Midas M32 LCR Sub Outs  (Read 939 times)
Timothy R Moss
« on: November 28, 2022, 07:11:11 AM »
I  am using 2 Meyer JMP-1 for tops.  They are driven by the L + R outputs (15-16) on the console.  I have two Meyer 900 subs that each need an output from the console. The typical routing for the sub would be C or output 14.  Since I need one out for each sub is there a way to add or sum 13 and 14?  Or do I need something else?
Thanks
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #1 on: November 28, 2022, 09:02:28 AM »
Thanks
Please go to your profile and change your name to your real full name as required by the posting rules.
admin
Jonathan Kok
  • Toronto
Re: Midas M32 LCR Sub Outs
« Reply #2 on: November 29, 2022, 01:18:54 PM »
You can assign a bus to multiple outputs. Simply assign the 'Main M/C' bus to another output of your console (probably 13). It's under the 'OUT 1-16' tab of the ROUTING page. Alternatively, you can instead use an AUX BUS for your subwoofers (common in the pro world); this would enable you to completely remove some inputs from being sent to your subwoofers.
Brian Jojade
« Reply #3 on: November 29, 2022, 03:00:24 PM »
Using the X32/m32, you have the option to turn the M/C buss on or off as well as adjust the level if you so desire on a per channel basis.  You could also turn off the main L/R on the channel and send the channel exclusively to the sub, if you so desired.  No need to burn an aux bus doing this.
I would also recommend setting the M/C channel to follow the LR main. This allows you to use just the main control to adjust the entire mix.  If you don't do that then you need to adjust both the main and the center control which may not both appear on the surface at the same time, depending on what you're looking at.
« Last Edit: November 29, 2022, 04:07:14 PM by Brian Jojade »
Brian Jojade
John Schalk
« Reply #4 on: November 30, 2022, 10:04:31 AM »
The picture of the 900-LFC on Sweetwater's website shows that the input panel has a loop through XLR output, so another way to get the audio signal to your second subwoofer would be to run a "jumper" mic cable from the first subwoofer.  This is what I do when I can locate my powered subs together, usually in a center position.  I realize that this seems terribly obvious, but just thought I'd mention it in case the OP is really new to audio.
