Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Pro AV Forum
USB-C video out and in options
Craig Hauber:
--- Quote from: Tim Hite on December 16, 2022, 12:03:04 AM ---The solution to Keynote is to ask for deliverables rendered to PDF. This fixes issues with missing fonts and images and Acrobat has a presentation full screen mode that works like powerpoint.
--- End quote ---
Just tried this based on your suggestion because I use acrobat daily and if you're already subscribed then might as well use it more.
Discovered the slides were mostly animation loop movies with sequential build-ins and outs. Tried loading all the raw components into a media server but it more than quadrupled my workload and cue-load!
So suddenly decided that I can tolerate Keynote on a dedicated Mac, so insisting now that deliverables include a turnkey pre-loaded Mac mini, that fortunately for now still have a native HDMI port, a native ethernet jack, a genuine 1/8" analog audio hole and still fit nicely into the open half of my Sonnet rack-mac unit.
Tim Hite:
--- Quote from: Tim McCulloch on January 11, 2023, 12:08:21 AM ---If you've got HDMI cables "falling out" of the Constellation I submit the connectors have been abused or used beyond their rated insertion life cycle.
One solution is to build a patch bay so the cables stay plugged into the Constellation, and you replace the patch bay HDMI jacks when they get loose. Also common on cameras (esp Mini HDMI and mini XLR and mini-everything else). Cage the camera and use short patch cables affixed to the cage.
--- End quote ---
The Constellation has SDI I/O only, there's no issue there. I already use short cables on my cams to jump to SDI converters.
The HDMI that are falling out are from my brand new M1 MacBook pro with on board HDMI and various client provided dongles.
The entire purpose of this thread is finding a better way to get video out to SDI from a laptop. I don't always have the option of using my own computers, either.
Brian Jojade:
--- Quote from: Tim Hite on November 21, 2022, 02:54:35 PM ---I have Radial USB Pro on the way. I am specifically trying to eliminate HDMI from the video equation, as I keep having problems with the non-locking connectors working their way loose at inopportune times. Someone bumps a laptop and the signal goes out, it's not a good look
--- End quote ---
Moving from a non-locking HDMI connector to a non-locking USB-C connector that may be running different protocols for different things is just moving the problem, not really solving it.
As far as HDMI cables coming loose, I've found that more often to be a problem with big fat stiff HDMI cables. Yes, any movement of the laptop then can mean the connection can work loose easily if the laptop or cable get moved. The solution is a short ultra-thin, ultra flexible HDMI extension cable that's a couple feet long. A piece of gaff can keep it secure if needed, but because it's much more flexible, movement of your laptop is much less likely to result in a dropped connection.
This is a $10 fix to your problem.
Tim McCulloch:
Friends don't let friends use laptops in mission critical production roles. I'm a firm believer in rack mount computers with patch bays in the rack. The life-limited connectors on the computer seldom get unplugged this way and if a patch bay connector fails, you just replace it and not the whole computer.
Tim Hite:
--- Quote from: Tim McCulloch on February 16, 2023, 09:15:29 AM ---Friends don't let friends use laptops in mission critical production roles. I'm a firm believer in rack mount computers with patch bays in the rack. The life-limited connectors on the computer seldom get unplugged this way and if a patch bay connector fails, you just replace it and not the whole computer.
--- End quote ---
That's the dream. I have a bunch of smaller corpy shows where the client wants to use their own presentation laptop because the CEO is editing his deck right up until the morning of the presentation. I try to get media in advance for prep but the curve balls keep coming.
"Hey I'm about to go on, you can just use my laptop for my presentation, it's all ready to go"
Morgan Freeman voice : "but it was not, in fact, all ready to go"
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
