Dialing powered sub in a 70v system
Mike Caldwell:
Your QSC amp would run three per channel your JBLC67 speakers set to 8 ohms with the amp in stereo mode.
Take the two stereo outputs of the Shure mixer to the inputs on the sub, take the sub outputs to the inputs on the QSC with the sub outputs set in the crossover output mode.
Not sure how much the C60 "subs" will help but use the Shure mixer aux outs to go to the Crown amp for the subs.
Myles Lemansky:
Mike,
I have a second input/output on sub, would running through sub to Crown amp utilize subs crossover to appropriately direct signal to C60s or there be little difference going through Shure?
Thank you.
Mike Caldwell:
The outputs on the sub are a high passed output that is not want you would want to send to the C60's, there is no low frequency on the sub outputs.
Navigation
[0] Message Index
[*] Previous page
Go to full version
