Author Topic: My turbo sound active speakers continue to fail.  (Read 2654 times)
DonnyCooper
« on: September 10, 2022, 03:15:08 AM »
Hello. I work at Gerties, the casino in Dawson City, Yukon Canada. Weve had a Turbosound PA installed for about six years. This year we had a brand new, beautiful lighting rig professionally installed. However in the last five months our turbosound tops have succumb to the same problem multiple times. I have a basic level of electronic repair understanding and have done the visually obvious repair a few times.Something is burning out the same transformer solder points on the AC side. Ive attached pictures and Im looking for insight. This is happening too often to be a coincidence.
« Last Edit: September 10, 2022, 03:21:15 AM by DonnyCooper »
Mike Caldwell
  • Covington, Ohio
Re: My turbo sound active speakers continue to fail.
« Reply #1 on: September 10, 2022, 08:05:12 AM »
Maybe the trace is not large enough to handle the current?
Have to jumper the trace with a piece of wire?
Brian Jojade
« Reply #2 on: September 10, 2022, 09:02:32 PM »
Have you checked your supply voltage?  A lower supply voltage results in higher current draw as the power supply compensates and sometimes that will push gear beyond its capabilities and cause premature failure.
Brian Jojade
Jim McKeveny
« Reply #3 on: December 08, 2022, 02:21:55 PM »
This is a common class D amp failure situation (if these are class D amps). The compensation for voltage sags is slow to normalize as voltage returns, resulting in overvoltage situations not designed-in. Class D's are a work-in-progress, but the wiser manufacturers have made great adjustments as fresh data emerges.
« Last Edit: December 08, 2022, 02:25:43 PM by Jim McKeveny »
Patrick Tracy
    • Boulder Sound Guy
« Reply #4 on: December 08, 2022, 05:24:04 PM »
Out of curiosity, which Turbosound speakers? They don't appear to be Milan, iQ or iX (looking at the flown speakers in the photo).
Page created in 0.033 seconds with 20 queries.
