Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > The Basement
CD improver
<< < (6/6)
Russell Ault:
--- Quote from: Helge A Bentsen on October 02, 2022, 04:44:33 PM ---Don't know about the AES50 ports, but the fun part with this kind of device is that every network switch has a 1:1 isolation transformer on the input.
So, you're isolating a transformer using a transformer  ::)
--- End quote ---
In theory all Ethernet-over-twisted-pair devices (not just switches) should have galvanic isolation (although IIRC at least one iteration of Raspberry Pi forgot to include it), but I've never seen an Ethernet device with a ground lift switch (although you're right that an extra set of transformers shouldn't be needed to lift ground, assuming your endpoints are behaving properly).
I suppose (for the truly adventurous) it's been suggested that DiGiCo's MADI-over-Cat5 implementation (or at least the SD9's version of it) lacks galvanic isolation; perhaps this is the "solution" for that. :D
-Russ
Navigation
[0] Message Index
[*] Previous page
Go to full version
