Author Topic: FBT ProMaxx 14a  (Read 229 times)
Lev Raber
FBT ProMaxx 14a
« on: July 22, 2022, 05:42:01 PM »
For sale FBT ProMaxx 14a powered speakers
ProMAxX 14a Specs:
600W RMS + 300W RMS 135,5DB SPL PROCESSED ACTIVE SPEAKER
2-way, bi-amplified, bass reflex design cabinet
NEW! 355 mm (14) LF neodymium magnet woofer with 75mm (3) voice coil, custom made for FBT by B&C
35 mm (1,4) exit throat B&C HF neodymium magnet compression driver with 64 mm (2,5) voice coil
Frequency response from 45Hz to 20 kHz
Biamped: 600W RMS LF, 300W RMS HF, Class D power amplifiers with switch mode power supplies
Digital signal processor with 8 equalization presets
Control Panel: features XLR input and link out, Volume, EQ Presets, HP Filter, Ground-Lift Switch
90H x 60V constant directivity horn
Compact Dimensions: ProMaxX 14a uses the same size gas-injected polypropylene molded enclosure as the ProMaxX 12a, but features our New  14 LF Woofer for morelow frequency SPL
Dual Purpose: Front of House or Stage Floor Monitor: with 12, 40 and 55 monitoring angles
2 x M10 suspension points, 35 mm (1,3/8) top-hat speaker stand socket, wall bracket mount flange plate
Dimensions(WxHxD) 500mm x 745mm x 440mm
Extremely light, only 16,5 kg (36,4 lb)
I have 2 pairs for sale in original FBT covers, very good to new condition. $1800 for the pair.
soundsgood55 at aol
Located in Staten Island, NY
« Last Edit: September 17, 2022, 10:09:55 AM by Lev Raber »
FBT ProMaxx 14a
Page created in 0.022 seconds with 20 queries.
