Author Topic: X32 - Send sub-group to FX?  (Read 556 times)
Rich Orde
« on: July 15, 2022, 09:39:12 AM »
Here is what I am trying to do and I am wondering if there is an easier way.
During a couple songs I use a timed delay based on the song BPM.  At certain points I want to send multiple vocal channels through that delay.  Problem is, I need to slide them up to the proper balance in time with when I want it to echo and pull them back down.  Either that or have each send muted and unmute them simultaneously.  This is a bit of a challenging task and often times it doesn't come out to my satisfaction.  I can't simply have the effect return muted and then unmute it because with the sends turned up, the processor is constantly being fed the vocals prior to when I need them sent.
So my question is: Is there a different way to accomplish this, perhaps a way to assign those vocals to some kind of sub-group and then with a single slider send that mix through the FX?  I looked around the mixer and it didn't seem like there was a way to send any of the sub groups to the FX.
Thanks for the help.
Helge A Bentsen
  • Oslo, Norway.
Re: X32 - Send sub-group to FX?
« Reply #1 on: July 15, 2022, 11:47:00 AM »
Adjust the send master to the fx instead of the return should do that.
I usually leave my returns open and adjust/mute the bus master going to the effect.
IIRC you can assign the bus masters to a VCA on the M32.
Rich Orde
« Reply #2 on: July 15, 2022, 04:26:15 PM »
M32 app used on the X32, or do you need the Midas console?
I always have the returns open and adjust the sends as needed.  I will have to find the send master.  It's not my mixer and I did not set it up so my only chance to experiment with it is at a gig.
Helge A Bentsen
  • Oslo, Norway.
« Reply #3 on: July 15, 2022, 06:52:58 PM »
Same software and features on both consoles, you should be able to set this up on both.
James Paul
« Reply #4 on: July 16, 2022, 05:11:23 PM »
Mixing Station third-party app can provide the means to accomplish such a task
 https://dev-core.org/ms-docs/layer-idcas/
Rich Orde
« Reply #5 on: July 17, 2022, 09:46:00 AM »
I did find the send master and that does the trick for what I need.   Thanks
Page created in 0.036 seconds with 20 queries.
