Author Topic: New Antenna Question  (Read 562 times)
Jamin Lynch
  • Corpus Christi, TX.
« on: May 05, 2022, 02:37:01 PM »
I've been using the Sennheiser A2003-UHF paddle antenna for wireless in ears as well as wireless mics a while. I noticed it has been discontinued and replaced with the ADP UHF paddle like the one shown in the picture.
Often times a new model will mean better. (not always of course)
Anybody know if the new model is in fact better? If so, in what way?
Thanks
Mike Caldwell
  • Covington, Ohio
Re: New Antenna Question
« Reply #1 on: May 06, 2022, 08:14:46 AM »
Set up outside it may no blow over as easy!
Brian Jojade
« Reply #2 on: May 13, 2022, 10:12:24 AM »
Looks like the same design simply with cutouts.
Less wind load, but potentially more fragile.
Brian Jojade
John Sulek
  • Toronto Canada
« Reply #3 on: May 13, 2022, 12:53:12 PM »
I've always found that the bnc/N connector solder pads are the point of failure on any of the paddle style antenna.
Brian Jojade
« Reply #4 on: May 13, 2022, 07:21:19 PM »
Yes, I'd agree.  The regular circuit board construction of normal paddles is extremely and surprisingly robust. But with this cut out design, you've now weakened that board tremendously. Under normal conditions it shouldn't matter at all, but in the event of getting hit with stuff, or getting things piled on it, I'm guessing it won't take as much abuse.  Additionally, with the holes there's better chance of it getting hooked on stuff unexpectedly.
Brian Jojade
Scott Helmke
« Reply #5 on: May 16, 2022, 09:54:24 AM »
The connector pointing down is a nice update.
Karl Winkler
    • Lectrosonics
« Reply #6 on: May 25, 2022, 06:04:03 PM »
I don't know about the Sennheiser version, but most of these are made from fiberglass circuit board material. Ours (Lectrosonics) are quite thick - 1/8" - and are extremely rugged. The BNC connector is not only soldered, but mounted with screws. We have sold many hundreds of these over the years and I've never seen one broken, nor heard of one snagging or catching on anything. The reduced wind drag, however, makes them much more friendly to use outside.
In theory, theory and practice should be the same. In practice, they are not.
Page created in 0.062 seconds with 25 queries.
