Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Console Connectivity Solutions
Behringer X32 rack : Aux out for in-ear mix (problem)
(1/1)
Olivier lemaitre:
Hello guys,
I’d need your help regarding the « aux out » on the Behringer X32 (rack version), we use that console for our band’s rehearsal and for live.
At first we were a 4-man band, we all use in-ear system in stereo and we are currently using the XLR outs from 1-8 for routed to individual mixbus.
Today for the new guy, we want to use his in-ear system (stereo) so we figure it would be okay to use the Aux Out (TRS) 1-2.
The problem is : it seems that the mix from the 1-2 Aux Out is the same as the 1-2 XLR out currently used by the other musician. Physically, different outputs are used, but in the mixer it is like the XL out 1-2 and the TRS out 1-2 are “linked”/copied.
Here is our actual routing setup in the Analog Out tab :
(analog out) XLR OUT 1 > (category) Mix Bus > (Output signal) MixBus 01 > (Tap) Pre Fader
(analog out) XLR OUT 2 > (category) Mix Bus > (Output signal) MixBus 02 > (Tap) Pre Fader
= In-Ear stereo mix 1
(analog out) XLR OUT 3 > (category) Mix Bus > (Output signal) MixBus 03 > (Tap) Pre Fader
(analog out) XLR OUT 4 > (category) Mix Bus > (Output signal) MixBus 04 > (Tap) Pre Fader
= In-Ear stereo mix 2
(analog out) XLR OUT 5 > (category) Mix Bus > (Output signal) MixBus 05 > (Tap) Pre Fader
(analog out) XLR OUT 6 > (category) Mix Bus > (Output signal) MixBus 06 > (Tap) Pre Fader
= In-Ear stereo mix 3
(analog out) XLR OUT 7 > (category) Mix Bus > (Output signal) MixBus 07 > (Tap) Pre Fader
(analog out) XLR OUT 8 > (category) Mix Bus > (Output signal) MixBus 08 > (Tap) Pre Fader
= In-Ear stereo mix 4
In the Aux out tab :
AUX Out 1 > (category) Mix Bus > (Output signal) MixBus 09 > (Tap) Pre Fader
AUX Out 2 > (category) Mix Bus > (Output signal) MixBus 10 > (Tap) Pre Fader
= In-Ear stereo mix 5
==> For example, when I add more bass signal in the mix n°5 (Aux out 1-2 thus), it will also add more bass in the mix n°1 (XLR out 1-2).
Any idea what’s wrong here ?
I’ve checked for hours in the settings but I can’t figure it out.
Thanks a lot in advance for your input ! :)
(sorry for my English, I’m no native)
Mac Kerr:
--- Quote from: olilem on April 03, 2022, 12:31:46 PM ---Hello guys,
--- End quote ---
Please go to your profile and change your name to your real full name as required by the posting rules.
admin
Olivier lemaitre:
--- Quote from: Mac Kerr on April 03, 2022, 12:51:42 PM ---Please go to your profile and change your name to your real full name as required by the posting rules.
admin
--- End quote ---
Done :)
Russell Ault:
--- Quote from: Olivier lemaitre on April 03, 2022, 12:31:46 PM ---{...} I’d need your help regarding the « aux out » on the Behringer X32 (rack version), we use that console for our band’s rehearsal and for live. {...}
--- End quote ---
The best way to get help with this sort of issues is to upload a copy of your show file so we can take a look (you may have to change the file extension to one the forum will let you upload).
-Russ
Navigation
[0] Message Index
Go to full version
