Pages: [1] 2 3 4   Go Down
Author Topic: Help looking for best PA speaker and sub  (Read 2333 times)
Jake Maxwell
« on: January 22, 2022, 02:25:46 PM »
Hello everyone. I want to upgrade my speakers system. I spent a lot of hours doing research, and just want to check in with yall before I make a purchase.
Im currently using a pair of EV ZLX-12BT powered speakers and a 12 EV sub. The speakers are used by a me and a few others to play a lot of EDM and hip hop, so bass is important.
I recently got a grant up to $8,000 to spend on 2 tops and a sub.
I At first I was going to go for QSC, but then I read that there are speakers out there that are better than QSC. These are some options below:
2x QSC K12.2 and a QSC KS118
2x JBL SRX812P and a JBL SRX818SP
2x Yamaha DZR12 and a DXS18XLF
Portability is also important so I dont want some 3-way speakers because of their weight.
Some of my questions I have are:
1) Which subwoofer has the best sounding bass?
2) Which sound system as a whole sound best overall?
3) How do they all compare to each other? Are one siginificantly  noticeable better than the others?
4) Did I miss any other brand or models than the one I listed?
5) How reliable are they?
6) Which PA speakers has the best sounding bass, if hypothetically, a subwoofer is not used?
7) Lastly, all the tops I listed are 12. I read that 12 generally  have better mids and vocal clarity than 15. Just wondering if that is true in all cases, even with high end products, or are there certain exceptions? And if so, should I go with 15?
Feel free to of course add any other comments about the experience. I just want to make sure I have the most up to date information since new products are being released all the time. Much appreciated!
« Last Edit: January 22, 2022, 02:45:01 PM by Jake Maxwell »
Caleb Dueck
Re: Help looking for best PA speaker and sub
« Reply #1 on: January 22, 2022, 02:44:28 PM »
6) Lastly, which PA speakers has the best sounding bass, if hypothetically, a subwoofer is not used?
Don't forget to add RCF to the list, and maybe other higher end brands as well, especially if used.
For subwoofers - also add JTR and Bassboss to your list.  The list above seems to only include basic MI grade options.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #2 on: January 22, 2022, 02:47:02 PM »
I'd say you need more subwoofer for those main speakers. 3 or 4x 18" per side wouldn't be out of the question, for EDM and other bass-heavy genres.
Chris
www.grimshawaudio.com
Chris Hindle
« Reply #3 on: January 22, 2022, 03:28:07 PM »
What is your crowd size? How large a hall do you play in?
If it were me, I'd keep the tops, and get a couple of double 18's
Chris.
Rick Powell
« Reply #4 on: January 22, 2022, 04:09:05 PM »
If the goal is to stay within your $8k funding, youd be OK with any of the 3 systems you listed, but as others said, look at beefing up the subs to get more low end capabilityIOW, 2 subs and one top per side. My personal preference would be the Yamaha DZR/DXS followed by JBL SRX and QSC K/KS. If you shop around, I think you may be able to get 4 subs and 2 tops of either system within your budget or just a hair above.
Brian Jojade
« Reply #5 on: January 22, 2022, 04:54:07 PM »
I'll concur with the previous posts.  You have an 8K budget, which is reasonable for an upgrade.  The single 18 inch sub could prove to be a little weak, especially for EDM.
With all of the kits you mentioned, all could easily fall within budget if you include a second sub in the kit.  I'd definitely also purchase covers for the speakers if you're moving them around and want to keep them looking nice, but that's just me. :)
As far as which one is 'best', well, that's going to depend on who you talk to.  Everyone is going to have their favorites and will be able to come up with a list of reasons why their decision is the right one.  When you compare speakers within similar price ranges, reality is, they are going to be quite similar, and you won't go wrong with any of them.  An $8K budget should put you in position to get a decent quality rig from any of the big name brands mentioned.
My recommendation is to keep everything you get within the same family vs mixing and matching between brands.  Not only does the rig end up looking better, generally their designs mean the speakers work better together without much additional thought.
A 12" Speaker on a pole over a sub is a nice clean looking setup.  I personally prefer that to speakers on tripods myself.  While having subs separated does have its drawbacks vs a center cluster, generally speaking it works just fine for most situations.  And, there's no rule that says you have to have both subs turned on if it's causing problems.
Brian Jojade
Dave Guilford
« Reply #6 on: January 22, 2022, 05:31:24 PM »
Get whichever is available.  Not everything is in stock these days.  Good luck with Yamaha or JBL.  Qsc seems to be hit or miss.
That said- Id guess that the srx818 is the best sub you listed
Jake Maxwell
« Reply #7 on: January 22, 2022, 05:34:39 PM »
Thanks everyone for your input. Im currently on a short lunch break, so I have to be brief.
I want to clarify that the free $8,000 grant explicitly states its only for exactly 2 PA speakers and exactly 1 subwoofer. So we cant get more than 1 sub unfortunately, and we cant use the funds for anything else or put the difference in our pocket.  Its a use it or lose it kind of thing. We just want to the best two PA speakers and a sub for under $8K. Rick replied and mentioned his personal preference is the Yamaha DZR, then JBL SRX, then the QSC K. Is that common consensus in the industry?
I will reply more throughly tonight when I get home to individual posts. Im curious if anyone have personal experiences with these speakers and can give an analysis of the differences in audio quality and other stuff asked in the original post. Thanks
Mike Santarelli
« Reply #8 on: January 22, 2022, 05:37:15 PM »
Id take a look at the rcf nx32 or nx45 and a pair of 8004 subs.
If you find the right deal you may be able to squeak in at $8k. Look at the 8003 to shave a few dollars.
« Last Edit: January 22, 2022, 07:06:43 PM by Mike Santarelli »
Jake Maxwell
« Reply #9 on: January 22, 2022, 05:39:37 PM »
QSC and Yamaha DZR seems to be in stock at GC currently. And what do you mean by QSC seems to be a hit or miss? 🤔
Pages: [1] 2 3 4   Go Up
Page created in 0.03 seconds with 18 queries.
