Pages: 1 ... 3 4 [5] 6   Go Down
Author Topic: Column speakers systems  (Read 2411 times)
Doug Fowler
  • Saint Louis, MO USA
Re: Column speakers systems
« Reply #40 on: January 12, 2022, 09:38:21 PM »
As Ivan mentioned regarding the SM80F LF,  it might take 2 x 12s or 15s to keep up with SM80.
Cheers
Martin
True but were also looking at maybe 80Hz cutoff rather than an octave lower as is the case with SM80F.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #41 on: January 13, 2022, 09:10:54 AM »
As always, it depends. Program material, crossovers, etc.
I think 2x12" running 80Hz-200Hz would do the job, but we can always double that up for more demanding applications.
Chris
www.grimshawaudio.com
« Reply #42 on: January 13, 2022, 09:20:28 AM »
It does make a difference.
There are penalties to be paid in any design.
If you want to go lower (and keep the same size), you lose output.  As a "general rule for low end" there is a 9dB/oct loss in output, keeping the same size.
So on the other hand, raising the cutoff, can either increase the output, or reduce the cabinet size (for the same output).
NOTE: There are a lot of variables and specifics involved, so "general answers" can often be wrong.
And then there are other physical constraints, that can affect what design to use.
In the case of the SM80F, the entire cabinet size is used for the low end, NOT just the area where the woofers are located.  The horn goes all the way to the top and back down again.  So it would not be as simple as "chopping the cabinet into 2 pieces" for smaller/lighter pieces.  The SM80 part is just a small part of the overall cabinet internal volume.
John Schalk
« Reply #43 on: January 13, 2022, 09:30:39 AM »
The following PA stack puts the bottom of the SM80 at least 6' 4" high and the total stack height is 8' 6".  The THMinis are laying on their sides and you can substitute any other tall sub you want as long as it's close to 24" wide.  The TTS 56 can be low passed from 60Hz - 90Hz and the THMini is spec'd out to 200Hz.
SM80         25.5" x 24" x 12.75"
THMini       15" x 24" x 24"
RCF TTS56 46" x 23.25"W x 39"D
Rick Powell
« Reply #44 on: January 14, 2022, 09:39:26 AM »
That's a lot of sub-division, LOL. a 5 way system. Would be interesting to hear how it sounds.
« Reply #45 on: January 14, 2022, 10:42:07 AM »
Subdivisions worked for RUSH. ;)
John Schalk
« Reply #46 on: January 14, 2022, 02:14:33 PM »
Well, I was thinking that it would be a two-way system with aux fed subs.  Both THMinis would be the "lows" and the SM80 would be the "highs" since, as I understand it, many SM80 owners choose to run them passive.  Mostly I was just posting the idea for fun when I saw that a THMini on its side would be the same width as an SM80.
« Reply #47 on: January 14, 2022, 04:59:50 PM »
The SM80 does not have an option to run biamp, only passive.
Scott Carneval
    • Cenero Audio Visual
« Reply #48 on: January 14, 2022, 07:58:32 PM »
What's wrong with the SM80M? I think someone mentioned it earlier in this thread. It has a -3 of 86Hz and a -10 point of 70Hz.
Or you could frankenstein your own, kinda like this 'OS80F' we came up with a couple days ago...or should we call it 'OS1180XL'?
Rick Powell
« Reply #49 on: January 15, 2022, 11:50:54 PM »
Plus, unlike its cousin the SM80, it is switchable to be either passive or bi-ampable if you want to run it that way.
Pages: 1 ... 3 4 [5] 6   Go Up
Page created in 0.028 seconds with 20 queries.
