Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Column speakers systems  (Read 2409 times)
Re: Column speakers systems
« Reply #20 on: January 10, 2022, 12:28:17 PM »
IMO SM80 needs a one octave bass box with the same footprint, say 80Hz - 160 Hz.  No one wants to run their subs high enough to account for SM80ís lack of bass response.  Itís also a stacking solution.
Hey now, "Back in the day" of the double scoops/ perkins boxes, 160-180hz was the typical xover between the low and mids for "the systems of the day". Sometimes a little higher
Of course things were different, nowhere near the deep bass we have today etc.
And I guess back then it was more of "bass cabinets" than sub cabinets.  The recorded media (LPs) didn't have deep bass because of the lack of tracking of the turntables, so most music didn't have much deep bass.
It all depends on what you are doing and expecting.
Doug Fowler
  • Saint Louis, MO USA
« Reply #21 on: January 10, 2022, 02:16:18 PM »
The SM80F (2-15's in a tapped horn along with the mid/hi section of an SM80) is a solution that some have used with a sub to solve the issue, and has decent low end response as a stand alone. Although at 215 lbs. it is much harder to deploy in a stack than a regular SM80.
There is also the SM80M which is a ported box instead of a sealed box, that is pole mountable and extends the -3dB LF response to 86Hz as opposed to the SM80's 140Hz. And weighs the same 65 lbs as the SM80. There's your missing octave.
Iím aware of the SM80F.  Itís the weight, hence the idea to split it.
Mike Santarelli
« Reply #22 on: January 10, 2022, 03:49:56 PM »
We are going to need that baby Jehrico!
Martin Morris
« Reply #23 on: January 10, 2022, 04:19:59 PM »
And not just the SM80F, also an option for the SM80.
And I wonder how many SM80 users would buy the "one octave" box? ... lots !!!
Bit like the d&b Q sub, compact and adds to the stacking height plus transitions nicely to the B2.
Cheers
Martin
Dude told me to "go back to where I came from", so I set my tent up on his front lawn ... (unnamed Indian)
« Reply #24 on: January 10, 2022, 08:54:58 PM »
A perfect application for Community's M-80 mid-bass horn. 100ish to 250Hz.
Doug Fowler
« Reply #25 on: January 10, 2022, 11:45:27 PM »
Cheers
Martin
Say your average sub is about 45 inches on end.  The bass box needs to be tall enough to get the center of the SM80 over the crowd, maybe 6.5 feet.  Half height of SM80 is about 12 inches. So the sub and center point of SM80 is about 57 inches.  We want to hit 78 inches, so the bass box should be at least 21 inches tall give or take, same footprint as SM80 or could be deeper with a cutout the SM80 can rest in.
Check my arithmetic please lol.
Yes box volume could be an issue, but itís not a sub.  For EDM the bass box would certainly add some ďsmackĒ.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #26 on: January 11, 2022, 01:43:50 AM »
Pair of 12"s in a short-ish horn would probably do the job. I'm thinking a similar layout to the Nexo B1.
If anyone's seriously interested in this, I'll knock some simulations together and see what we can get.
Chris
www.grimshawaudio.com
Doug Fowler
« Reply #27 on: January 11, 2022, 02:14:37 AM »
Chris
Sounds like a worthy project.
Peter Morris
« Reply #28 on: January 11, 2022, 02:40:55 AM »
Chris
What about a pair of 15's (that others mentioned)  :)
https://www.danleysoundlabs.com/products/loud-speakers/synergy-molded-horns/sm80f/
I don't think you will be able to do much better than this tapped horn + SM80 when you take every thing into account.
To me adding a couple of 12" drivers to fill the gap is not a great solution.  You are better off with an SM80F or with a different box such as a couple of SH 46's. That way you maintain the "Synergy Horn" point source concept.
https://www.danleysoundlabs.com/products/loud-speakers/synergy-horn/sh46/
To fill the gap you are talking about is what my PM90/60 that Caleb mentioned above was all about - 2 x horn loaded 12" speakers operating down to a usable 100Hz and a dual concentric horn driver operating from 650Hz up (B&C DCX464 in the latest version)
« Last Edit: January 11, 2022, 09:36:28 AM by Peter Morris »
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #29 on: January 11, 2022, 08:28:46 AM »
Peter,
The midbass module mentioned here would allow an amount of modularity in terms of building a system, which I suppose would be beneficial, but I do take your point that other products offered will happily do the job.
At the moment, I've got 1x12" simulating >[email protected] from 100Hz-400Hz, and with a ported back chamber (preferred for airflow) you can get useful output below 100Hz, albeit at a lower sensitivity - EQ required for a flat response.
Chris
¬ę Reply #29 on: January 11, 2022, 08:28:46 AM ¬Ľ
Pages: 1 2 [3] 4 5 6   Go Up
Page created in 0.03 seconds with 21 queries.
