Author Topic: Nema 15 and 12 ga SO  (Read 1966 times)
Jeff Lelko
  • Cape Canaveral, FL
Re: Nema 15 and 12 ga SO
« Reply #10 on: November 27, 2021, 12:46:13 AM »
If you have to drill them out to get #12 to fit, it's highly unlikely they are listed for use with #12-the manufacturer certainly knows what size hole is needed for #12.  It could be something that you do not see-perhaps the number of thread engaged in the base of the clamp.
Yes, I 've made things work before-but I really feel like it should be a field work around, not part of a planned build.  Just my opinion.
I second this.  Especially when it comes to electrical and rigging you’re taking on substantial liability by physically modifying components.  If one needs to do such a thing it’s likely that the hardware in question is the wrong part for the job all together and should be replaced by a more suitable option.
Kemper Watson
« Reply #11 on: November 28, 2021, 11:00:41 AM »
 I'll try your recommendation today
« Last Edit: November 28, 2021, 11:19:30 AM by Kemper Watson »
Geoff Doane
  • Halifax, NS
« Reply #12 on: November 28, 2021, 01:47:35 PM »
It looks like Kemper edited his last reply,  but here are the spec sheets for the two plugs I suggested:
https://hubbellcdn.com/specsheet/WIRING_HBL5965VY_spec.pdf
https://hubbellcdn.com/specsheet/WIRING_HBL5266C_spec.pdf
Those are the Canadian spec sheets, but I'm pretty sure the only difference with the US ones is you can't use a Robertson screwdriver on them.
In a nutshell, the 5965 is rated for stranded copper conductors from 18 ga to 12 ga.,
and the 5266 for stranded copper from 18 to 10 ga.
Perhaps some of the "clone" plugs from Leviton, etc. have slightly different specs, but I know for a fact that 12 ga. will fit easily in the 5965, having put one on a piece of 12/3 SJ just the other day.
GTD
Jeff Lelko
« Reply #13 on: November 28, 2021, 02:33:02 PM »
It looks like Kemper edited his last reply…
He did, originally asking for working suggestions to which I was going to point back to Replies 1, 2, and 6.
In addition to the suggested Hubbells I’ve put on probably over 100 of the Leviton or P&S plugs - all of which fit #12 SOOW just fine without the need for any modifications.
Kemper Watson
« Reply #14 on: November 28, 2021, 04:51:46 PM »
My apologies. I didn't realize you had already replied. I don't know where I got this cable but the outer jacket is thick and the outer clamps won't come together unless I take a round file and route out the middle. Unless I do this there is an almost 1/4 gap showing the two screws and it just looks bad. That was what I was alluding to not modifying the inside.
Steve-White
  • Fort Worth
« Reply #15 on: November 28, 2021, 04:55:20 PM »
Augggg well aughhhhh I was replying to simply drilling out the innards and not having to mess with the cable clamp.
Get connectors that fit.  :)
Tim Hite
    • Bad Quail
« Reply #16 on: November 28, 2021, 06:44:10 PM »
I've used the Hubbell 5266EBK and 5269EBK connectors with Carol 10/3 SOOW. They take cord diameters up to 0.72 inches.
This is what I use, as well. The EBK are all black Hubbell Entertainment Devices. They will definitely accept 12/3 SOOW. I have not gone bigger than that.
Hubbell 5266CM2 is also all black but has a smaller opening for the cable clamp. 12/3 will fit in the terminals but the clamp is a mighty PITA to get installed on SOOW and required modification.
Bad Quail
Sound + Light
Joshua Tree, California
Page created in 0.045 seconds with 22 queries.
