Author Topic: Nema 15 and 12 ga SO  (Read 1964 times)
Kemper Watson
« on: November 25, 2021, 10:17:22 AM »
I know this has been asked before but is there a manufacturer that has a 15 amp plug that easily fits SO? I need repair to a few cord ends.
Geoff Doane
  • Halifax, NS
Re: Nema 15 and 12 ga SO
« Reply #1 on: November 25, 2021, 11:53:11 AM »
Hubbell 5965 has always been my go-to for SJ or SO.  Just remove the black inserts for the larger jacket.
If you want to spend more money, the 5266 gets the nod.
GTD
Jeff Lelko
  • Cape Canaveral, FL
« Reply #2 on: November 25, 2021, 02:03:34 PM »
In addition to Hubbell both Leviton and Pass & Seymour make suitable options that are usually available at your local home improvement warehouse if youre in a pinch.
Steve-White
  • Fort Worth
« Reply #3 on: November 25, 2021, 02:16:28 PM »
You talking about fitting the sheathed cable through the clamp or the conductors into the contact pad area?
I've drilled a few out to fit #12ga wire conductors over the years.
Kemper Watson
« Reply #4 on: November 25, 2021, 02:46:48 PM »
I guess I need to try that.
Steve-White
  • Fort Worth
« Reply #5 on: November 25, 2021, 03:18:36 PM »
Many of them are made to fit up to 14ga and need a little modification for 12ga.  Usually not a big deal, just be sure an hold things securely so the bit doesn't grab when going through or it can trash things out.  :)
Paul Miller
« Reply #6 on: November 26, 2021, 04:28:35 AM »
I've used the Hubbell 5266EBK and 5269EBK connectors with both 12/3 and 10/3 Carol SOOW. The EBKs fit easily with no modifications. They take cord diameters up to 0.72 inches and conductors up to 10ga. Specs
Edit: Clarify cable fit and link to specs
« Last Edit: November 30, 2021, 04:53:07 AM by Paul Miller »
Steve-White
  • Fort Worth
« Reply #7 on: November 26, 2021, 07:52:04 AM »
I've used the Hubbell 5266EBK and 5269EBK connectors with Carol 10/3 SOOW. They take cord diameters up to 0.72 inches.
It's not the cable diameter going through the clamp that's the issue.  It's each conductor going into the connectors, some 15A rated devices will not accept #12 wire gauge, some will.  When encountering this condition, I've simply drilled out the connector body to accept #12 wire gauge.
Stephen Swaffer
« Reply #8 on: November 26, 2021, 10:10:10 PM »
If you have to drill them out to get #12 to fit, it's highly unlikely they are listed for use with #12-the manufacturer certainly knows what size hole is needed for #12.  It could be something that you do not see-perhaps the number of thread engaged in the base of the clamp.
Yes, I 've made things work before-but I really feel like it should be a field work around, not part of a planned build.  Just my opinion.
Steve Swaffer
Steve-White
  • Fort Worth
« Reply #9 on: November 27, 2021, 12:34:00 AM »
I've done it making power adapter pigtails for smaller systems where 15A receptacles are the only source available.  I'm not talking about modifying the cable clamp for the outer sheath where it exits the device.  The individual conductor holes where the wires penetrate the device - some will fit 12ga and some won't.
« Last Edit: November 27, 2021, 12:53:11 AM by Steve-White »
Page created in 0.036 seconds with 21 queries.
