Author Topic: Digico SD8 Offline Editor - Outputs unavailable?  (Read 485 times)
Josh Bessom
    • Lazy Preacher
« on: November 17, 2021, 03:41:45 PM »
Figured I'd experiment with rack sharing at the console, tried some settings, then restored to full control with the FOH SD8...now with every show file I save on this console, when opening in the offline editor outputs are unavailable.  I cannot see a way to re-enable them in the offline editor.  This is a major workflow hindrance and makes offline editing nearly impossible.  Any ideas?  I have already tried opening and re-saving at the console, no change.
Brian Bolly
  • Homeward Bound
Re: Digico SD8 Offline Editor - Outputs unavailable?
« Reply #1 on: November 17, 2021, 11:01:07 PM »
Sounds like you've disabled all outputs on an Optocore rack.  In the editor, Master Screen -> Setup -> Audio IO -> Rack -> Setup Optocore there's a button for "Disable all outputs" (and when disabled) "Enable All outputs".  Will be in the bottom right once you've selected Setup Optocore.
When you're saving on the actual surface, something to do with your splits & sharing has disabled them, possibly in your scope.
Chip Sciacca
« Reply #2 on: January 14, 2022, 10:01:43 AM »
Hi Josh
Without seeing what was changed I would recommend you start fresh by deleting the startup.ses and sd8.ini file found in the SD8 folder installed on your computers drive. on next launch all settings should be reset as they were on first install.
Tech Support Engineer
Group One Ltd.
DiGiCo USA
Klang USA
Jim McKeveny
« Reply #3 on: January 14, 2022, 10:42:47 AM »
Hi Josh
DO NOT TRUST CHIP !!
(J.K. Your best advice comes from Chip).
« Reply #4 on: January 14, 2022, 10:55:23 AM »
I heard rumours of a Chip shortage....
