Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Pro AV Forum
Automatic Mixer/Manual Mixer
(1/2) > >>
Chris Phillips:
Good morning. We have a high school auditorium with the current configuration:
A Yamaha MG16XU Mixer is located in FOH Control Room.
4 Microphone cables terminated with 2 XLR  wall input plates on both sides of stage with cable runs to FOH Mixer inputs
Amplifiers and processing systems are located in a closet side stage
Cable runs from output jacks of the FOH mixer to the amplifiers/processing equipment located side stage in closet
We are installing a Shure SCM810 automatic mixer in a small rack in the FOH control room next to the current Yamaha MG16XU main mixer.
After installing the automatic mixer, we are placing the main Yamaha mixer in an SKB case, locked.(Still next to the automatic mixer rack)
We would like to have the main Yamaha mixer turned off and not in the signal chain when the automatic mixer is what is being used. (Most circumstances)
When the main mixer is needed, we would like to bypass the automatic mixer and someone can live mix using the main Yamaha mixer.
I am thinking we would need a switch that would toggle between auto and manual depending on the situation.
May someone help me to verify this would work and what I would need to do for the specifics of installing this. I have been on the RDL website looking to see if one of their stick on devices would work. I appreciate your assistance.
Steve-White:
Without knowing how many outputs the system uses.
Pretty much any system controller will switch between inputs - any system controller that has input to output matrix routing capability.
Depending upon your budget, future system growth and overall planning will influence which solution is best.
A used dbx Driverack VENU360 would do the job at the lower end of solutions.  Throw money at it from there and the sky is the limit.
Caleb Dueck:
--- Quote from: Chris Phillips on October 27, 2021, 09:21:08 AM ---Good morning. We have a high school auditorium with the current configuration:
--- End quote ---
What you're describing is the exact type of application where you need a DSP.  Not just a speaker processor type DSP, but a full system processor (QSys, Xilica, Tesira, Symetrix, etc).  When the system is turned on, from the touch screen you select manual mix or auto mix.  For manual mix - typically there'll be a wireless or wired touch screen, or both.  A physical mixer isn't needed or desired unless you specifically need compression, EQ, FX, etc - IE, an experienced tech and a full band.  The touch screen GUI is programmed for whatever you need - typically faders and mutes for the various sources when manually mixed.
A wireless touch screen, typically an iPad, can be used while walking the room or sitting outside the tech room - which is usually at a bad spot anyway.  It can also be used to sequence the system, turn the projector/screen on/off, operate the background music (Sonos, Bluesound, etc), and recall lighting presets.
Mike Caldwell:
If buying new for what you pay for a Shure SCM810 for not so much more
you can get a Allen Heath QU16 that will do what the SCM810 does and much more
and doing it better all the while.
You could have an auto mix scene for daily use and a full mix mode scene for special events.
For daily use the operators could use the Q Control app to only get to and adjust the minimum needed controls.
Chris Phillips:
--- Quote from: Mike Caldwell on October 27, 2021, 05:36:02 PM ---If buying new for what you pay for a Shure SCM810 for not so much more
--- End quote ---
I think you had suggested that on another thread, and I looked it up right away. It is fantastic. Unfortunately, I can only use what we have right now.  I found this: https://www.rdlnet.com/product.php?page=150
Do you think this would work using a switch?
Navigation
[0] Message Index
[#] Next page
Go to full version
