XR18 and X Air: change pre/post per channel?
(1/1)
Kirby Yarbrough:
Just picked up an XR18. With X Air or X Edit, is it possible to change pre-post on a per channel basis? I want to send tracks to individual monitor mixes as well as the main LR mix.
brian maddox:
--- Quote from: Kirby Yarbrough on September 28, 2021, 08:35:17 PM ---Just picked up an XR18. With X Air or X Edit, is it possible to change pre-post on a per channel basis? I want to send tracks to individual monitor mixes as well as the main LR mix.
--- End quote ---
You can change the pick off point for Mixbuss sends to several different options on a channel PAIR basis. So as long as you plan your inputs wisely, you can likely get what you want.
You'll find the pick point on X edit if you select a channel and then select sends from the drop down pages available across the top of the editor.
Lou Kohley:
Also when in the pc version of the software, under the sends tab, there is a button that says "Changes affect selected chn." with a big global icon.
When this button is on, any time you change a send from pre to post, or subgroup it happens "globally to all channels"
When not on you can change individual channels sends.
LOU
Navigation
[0] Message Index
Go to full version
