Pages: 1 [2] 3  All   Go Down
Author Topic: More sub opinions  (Read 8119 times)
Nick Pignetti
    • Event Pro Live
Re: More sub opinions
« Reply #10 on: April 07, 2011, 03:44:48 pm »
Yeah, that's why all the arena tours are using only horn subs.
...Not.
I don't think that's how he meant that Bennett... I think he was genuinely asking him that question to see his response, not because he actually believes that concept. Maybe I mis-interpreted it.
duane massey
« Reply #11 on: April 07, 2011, 09:12:10 pm »
Don't assume all horn-loaded boxes are folded. They are uncommon, but a front-loaded horn is a different animal than the standard folded variety. Just too damn big for most mobile use..
Duane Massey
Houston, Texas
« Reply #12 on: April 08, 2011, 07:28:49 am »
This is my experience. I've used both front loaded and horn loaded subs. Each seems to have their strengths and weaknesses. You must decide which is right for you based on your usage.
Horn loaded subs are very efficient but they tend to be very hot at their resonant frequency. Some call it "one note bass" because one frequency seems to dominate the room far more than the others. Although EQ tweaks can help to control this. Horn loaded subs seem better suited for long-throw, outdoor events.
Front loaded subs are not as efficient but they tend to sound more smooth and natural. Thus, it takes twice as many to keep up with the system. Front loaded subs may be better suited for short-throw, smaller indoor events.
I would not throw all horn loaded subs into the same "pot".  Yes there are the classic "one note bass" cabients that were designed to get loud around a certain freq, but then there are others that have a much smoother response.
Why do you think horn loaded subs are better for longer "throws" and front loaded is better for smaller rooms?
Agreed there are advantages and disadvantages to each type-but the points you have made are not regarding that.
NOTE TO SELF: Don't tell anymore newbies what my experience has been. Others don't like it if it not the same as theirs.
It is one thing to state your preferences-but it is also important to understand the difference between opinion and fact.
It is very possible your "experience" has been limited to the certain type of cabinets.  But they don't all fall into that category.
If horn subs are for "long throw" applications-then explain how (properly designed ones) work in small rooms and why (as Bennett said) large tours are mostly using front loaded subs?
For example-"Diesel cars can't go real fast".  Fine-tell that to the guys that won the petiti la mans here a few years back.
Just tyring to "keep it real".
Brad Weber
  • Marietta, GA
« Reply #13 on: April 08, 2011, 11:25:03 am »
Ivan is hardly a newbie and I'm not sure what about his post garnered this.
There certainly may be some generalizations regarding speaker designs that are often valid, but not necessarily always valid.  Subwoofer design, and speaker design in general, involves many decisions and compromises and the decisions made for one product may be quite different from the decisions made for another product even if they share some basic physical similarities.  You often have to look at the 'bigger picture' and not just one particular factor.
Bennett Prescott
  • This text is personal!
    • Bennett Prescott Dot Com
« Reply #14 on: April 08, 2011, 02:17:43 pm »
...Not.
Sorry, I see how that could have been read. I was supporting Ivan in his questioning of Gordon's pigeonholing.
-- Bennett Prescott
Director of North American Sales
ADRaudio d.o.o.
Cell: (518) 488-7190
"Give me 6dB and I shall move the world." -Archimedes
Gordon Brinton
  • ID Verified
    • Raw Depth Sound, Harrisburg, PA
« Reply #15 on: April 10, 2011, 08:38:50 am »
The horn loaded sub that was mentioned by the OP does indeed have that inherent 100Hz hump which promotes "one note bass." (Based on the published response chart, 100Hz is roughly twice as loud as 50Hz.) I was only trying to make him aware of this phenomena.
As far as "long throw" duty, it is my understanding that horn subs have an easier time of getting the sound energy to go further due to the directionality that the horn provides. It tends to funnel more of the lowest frequency energy in one direction and thus would do better in longer venues. If I am wrong then I'll shut-up about it.
PS. Ivan was not the one that I was calling a noob.
« Last Edit: April 10, 2011, 08:41:37 am by Gordon Brinton »
Member since 2005.
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #16 on: April 11, 2011, 12:10:31 am »
Given that the lower frequency wavelengths are measured in 10s of feet, it takes a pretty big horn to have any directional control. And, the "Inverse Square Law" is still in effect! You can predict the volume at any distance knowing the SPL at one meter and it isn't affected for the most part by the cabinet design.
Now, multiples of various cabinets may change this behavior.
George Dougherty
« Reply #17 on: April 11, 2011, 10:17:29 am »
The short vs long throw is probably due to the harmonic distortion already mentioned.  Folded horns will filter out more of the low-mid harmonic distortion inherent to woofers.  A reflex box has more broadband output contributing to an impression of punch up close that gets absorbed by bodies and air.
The punch/thump of a system ranges from 60-120+Hz.  Having punchy top boxes with plenty of power in the 120Hz range is just as important, though you can roll off the subs higher as well to help augment that if you have to.  That's getting into a wavelength that becomes spatially locatable though and is not what I'd rely on to carry that 100Hz+ range.
Bennett Prescott
« Reply #18 on: April 11, 2011, 01:34:11 pm »
I suggest you mute your mains and see how much punch/thump the subs actually provide, even up to 120Hz. I suspect you will be surprised that it all sounds like mush without significantly higher frequency components.
-- Bennett Prescott
ADRaudio d.o.o.
George Dougherty
« Reply #19 on: May 18, 2011, 02:16:01 am »
Or try rolling the tops at 140Hz and turning off the subs.  There is a definite lack of impact, which is what I was addressing.  Yes, subs are mush without tops, especially with a gentler slope like 24db/octave and all the low-mid content they still produce.
My point was more about how the combination is as important.  Tops that come down to 150Hz and subs that come up to 100Hz do not produce as much impact/punch/thump however you want to describe it.  A combination that is strong through the crossover region will yield a result that is significantly better than one that's weak on either side.  Of course, given your posts, I know you already know that.
Pages: 1 [2] 3  All   Go Up
Page created in 0.052 seconds with 22 queries.
