Author Topic: Amps buzzing in a newer venue  (Read 874 times)
Kemper Watson
« on: August 08, 2021, 01:34:52 PM »
I know this has been discussed but I just wanted to maybe start a thread on what to look for in this situation with main causes and what can be done. I had a friend call me from Fla this weekend from a wedding type venue and had this issue. Maybe make this or start a sticky thread on problems and solutions?
 It was only the guitar amps . I was told that they had three prong connectors. All were tube amps
Thanks in advance
Re: Amps buzzing in a newer venue
« Reply #1 on: August 08, 2021, 02:28:52 PM »
Guitars are high impedance, so perhaps a noisy magnetic field from fluorescent lamps?
Of course building wiring is always suspect.
Kemper Watson
« Reply #2 on: August 08, 2021, 04:24:49 PM »
He texted after I posted this. The lights were a big part but it never really went away. Once the lights were dimmed the buzz went to about half. .
Brian Jojade
« Reply #3 on: August 08, 2021, 09:31:04 PM »
Were the guitars plugged in when the buzzing happened, or was it just the amp on its own?
The type of lighting in the venue can make a big difference.  Some LED lights output a huge amount of hash that single coil pickups in guitars can't handle.  Not a whole lot you can do about that short of building a faraday cage around the stage.
Brian Jojade
Jordan Wolf
« Reply #4 on: August 10, 2021, 08:45:46 AM »
Hmm...any neon signs close-by?
Jordan Wolf
« Reply #5 on: August 10, 2021, 10:26:07 AM »
If you get dimmer noise in amps, likely there's a bootleg neutral/ground bond someplace.
Kemper Watson
« Reply #6 on: August 14, 2021, 07:18:49 AM »
I bet that's it.
Jordan Wolf
« Reply #7 on: August 14, 2021, 11:53:50 PM »
Subpanel feeding the stage?
Jordan Wolf
« Reply #8 on: August 15, 2021, 10:50:46 AM »
Neutral/ground bonds away from the power panel (to grab a bootleg ground) are ill-advised and can be dangerous for multiple reasons. Increased chassis ground noise is only one of those several reasons.
Chassis/safety grounds are far from clean audio grounds.
Guitar pickups/amps are high impedance so susceptible to electrical interference (noise).
Page created in 0.084 seconds with 25 queries.
