Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > DJ Forum
jbl srx725 fullrange
<< < (2/5) > >>
Dave Garoutte:
Also make sure the polarity isn't flipped.
elie baele:
Hello.
i made some pictures to show the room and what i m doing
https://www.dropbox.com/sh/cyiyg2ddgir7cq0/AADKx4p7SBaw8ZCAbO2Y_kd5a?dl=0
first the plan of the srx was to make room on the floor by flying them. so this is kind of a must... if sound can be ok.
u seee the pic hk setup earlier. there are 2subs stacked on 2 others and 2tops hanging. u cant see clear but in the right corner there is a 500l aquarium (filter use)->witch is why im trying to avoid a 18inch :-)   earlier days the 4subs from hk ware at one line at the back against the wall this was best sounding!
so now u will see on the other pics still 2subs stacked against the wall behind the decks but they have to go to make room there.
is i follow your comments i could say my testing i m doing now is kind of useless as the sound will do change. i was planning to do some soundchecking and then hanging them in place but i see what u mean and maybe better have to place them first. maybe its just working out fine then.
u see the pictures right and left upper corners this is where i would like to hang them. i made a "plan" to make clear what i would like to do.  please your advice!! thanks
--- Quote from: Paul G. OBrien on August 05, 2021, 05:39:40 PM ---Actually there is more than a slight chance that the listining position is in a low bass null.
To the OP... try this, boost the lowend as you have done and then move around the room to hear where the bass is heaviest. If you get lucky that will be a suitable place to reposition your mixing desk, but if the room is really small you may find the big bass is in another room in the house.
--- End quote ---
lindsay Dean:
Just as a side note about the aquarium in the corner, or in the room at high levels
 it's where the fish are going to be most affected.
  It's not really good or happy for the fish to be sonically assaulted.
elie baele:
Thx for the concern! but the aquarium only holds filter material, pumps and sponges it s a sump filter :-) the fish are in the other room :-)
--- Quote from: lindsay Dean on August 06, 2021, 12:56:04 PM ---Just as a side note about the aquarium in the corner, or in the room at high levels
--- End quote ---
Don T. Williams:
At one time it was recommended that if speakers face each other, the polarity should be flipped on one of the speakers.  Try it both ways and see if that helps.  There are numorious bass "enhansers" that creat the illusion of more bass.  The DBX 120A is well known.  The Peavy Kaos is another.  A competing music store sell one of these on every HOW system.  I'm not certain why or if they get used, but they can certainly do wierd thing to the pastors voice when used incorrectly!
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
