Pages: 1 [2] 3  All   Go Down
Author Topic: jbl srx725 fullrange  (Read 4126 times)
Art Welter
Re: jbl srx725 fullrange
« Reply #10 on: August 07, 2021, 05:47:18 PM »
At one time it was recommended that if speakers face each other, the polarity should be flipped on one of the speakers.
Don,
Whoever recommended that is wrong, unless one driver has been mis-wired, or put in backwards.
Steve-White
  • Fort Worth
« Reply #11 on: August 07, 2021, 05:57:23 PM »
Those SRX725's if working properly and powered up right should all but blow that room apart.  I've seen DJ setups with 4508 dual 15's loaded with JBL 2205's, powered with BGW 750's with the stacks on picnic tables outdoors that sounded great - plenty of LF.
elie baele
« Reply #12 on: August 09, 2021, 04:06:37 PM »
did check of the +\- they ware ok. also checked for original driver.
disconnected the dcx and connected the old scool eq.  al below 80 +12db  and 40-20 on0 again. did sound kind of ok but i m afraid i m really pushing drivers this way
Mike Caldwell
  • Covington, Ohio
« Reply #13 on: August 09, 2021, 07:37:52 PM »
Do you mean on the graphic EQ everything from 40 to 80 was boosted +12?
Steve-White
  • Fort Worth
« Reply #14 on: August 10, 2021, 12:08:04 AM »
If you are in need of more 40hz and lower, why not just fly everything?  Put a mono dual-18 sub in the middle and done.
elie baele
« Reply #15 on: August 10, 2021, 02:03:51 AM »
yes
elie baele
« Reply #16 on: August 10, 2021, 03:40:11 AM »
yes
sorry used wrong quote. yes was on the graphic eq question
Steve-White
  • Fort Worth
« Reply #17 on: August 10, 2021, 06:31:57 AM »
+12 db @ 40hz is a dangerous setting for your gear.  At the low end of system bandwidth, +6 would be the most I would attempt to use.  And then for playback (recorded music) only where things were controllable.
elie baele
« Reply #18 on: August 10, 2021, 03:22:00 PM »
Hey i will try tomorrow (when neighboures are awake) to test with 40Hz 0db.
Today i put one sub horizontal at the ceiling....WOW what a difference in sound!!! the other is still standing in front of the bar(facing eachother) but planning on hanging him also this weekend.
I was also playing with the tought to get an extra EX4000 and run them both bridge each at 1 speaker to get more headroom... really the sound is really ok now but running cliplights kind of fast (beacouse of the +12db... ? )
love to hear your toughts
« Last Edit: August 10, 2021, 03:24:09 PM by elie baele »
Mike Caldwell
  • Covington, Ohio
« Reply #19 on: August 10, 2021, 04:24:19 PM »
You'll have to start being more careful when you run a bridged EX4000 per cabinet.
How are you suspending the 725? Do you have the version with the threaded fly point inserts?
Pages: 1 [2] 3  All   Go Up
Page created in 0.031 seconds with 21 queries.
