Hi,
Hopefully one of the x32 expert users can help with a strange issue I had this weekend.
Setup with 4 monitor mixes on mix buses 1-4 and effects on 13-16 asnormal.
Using the right bank of faders, using the button to switch control between bus1-8 bank bus9-16 the bus faders don't retain their setting. I keep finding buses 1-4have dropped to zero and have to manually push them up.
Another anomaly - if I switch the left bank of faders to bus master. The fader for each bus should follow each other - move the right bank and the corresponding left fader follows, however if move the left bank it will only lower the matching right hand fader - it won't lift it.
Everything else on the desk appears to be as expected and behaving properly. I've just had a play with the desk and it is acting the same way. In the end I've tried a factory reset but it is still the same.
Have I missed a setting or configuration control that would cause this?
Thanks in advance for any suggestions.
