Peavey IPR chaining
<< < (2/2)
W. Mark Hellinger:
--- Quote from: John Roberts {JR} on July 11, 2021, 10:07:41 AM ---That amplifier is after my time but in general with Peavey products try the logical hook up connection and see if it works.
--- End quote ---
Update:  I've finished assembling the rack, including chaining the amps per the logical hook-up, and tested, and it seems the parallel put-through is unaffected by the mode switch setting.
John Roberts {JR}:
--- Quote from: W. Mark Hellinger on July 13, 2021, 08:32:15 PM ---Update:  I've finished assembling the rack, including chaining the amps per the logical hook-up, and tested, and it seems the parallel put-through is unaffected by the mode switch setting.
--- End quote ---
As i recall most Peavey gear is designed to work despite the typical customers...
 I'm sure you are fine..
Navigation
[0] Message Index
[*] Previous page
Go to full version
