Author Topic: x32 x-live SD card recording question  (Read 496 times)
Jeff M Hague
« on: June 21, 2021, 04:20:02 pm »
Hey all!
Has anyone found a way to record the onboard effects returns to the SD card using an x-live card?
The documentation (mostly youtube videos unfortunately) show the basic how to record the inputs but I cant find anything on routing the effects returns to the SD card.
Thanks!
Jeff
Jeff
Douglas R. Allen
Re: x32 x-live SD card recording question
« Reply #1 on: June 21, 2021, 06:00:42 pm »
Hey all!
Thanks!
Jeff
   With enough spare channels you can. You can assign Effects to go out your Aux Channels. In this example I sent Effects 1 L/R out Aux Channels 1 and 2. Take a short 1/4 TRS to TRS cable and put those channels back into Aux 1/2. Now assign Aux In Channels 1-2 to a normal pair of channels. Say 31 and 32. Assign these channels to the card and you will have them. Clunky I know but it will work. Remember not to assign 31/32 to anywhere it shouldn't go as well as Aux 1 and 2 in, and certainly don't send 31/32 or Aux 1/2 back to Effects 1 !!! . Just 1 way I've done this before.
   Douglas R. Allen
Brian Adams
    • Adams Production Services
« Reply #2 on: June 23, 2021, 12:24:11 pm »
   Douglas R. Allen
This is the only way to do it that I can think of too, but why not just set the channels input source to be the bus output rather than running a cable? Seems like it would eliminate the conversion latency of going out and back in again with an analog signal. I've never tried, but is there a reason that wouldn't work?
Brian Adams
Vermillion, SD
adamsproductionservices.com
Douglas R. Allen
« Reply #3 on: June 23, 2021, 12:53:09 pm »
Aux in Remap and Soft Patch doesn't allow for that.
EDIT:  It looks like you can run effect straight into a channel. I've never tried it as I'm unsure if this is Pre Effects send or post. I'll do it here in a moment and report back.
Douglas R. Allen
« Last Edit: June 23, 2021, 01:01:38 pm by Douglas R. Allen »
Douglas R. Allen
« Reply #4 on: June 23, 2021, 01:22:03 pm »
   Good answer. I just tried it and it worked fine. The tap is Post Effects Processor. I was thinking about it and I remembered what happened the night I tried it. I patched in Effects 4 direct to a channel. Effects 4 just had had a short 80ms delay in it. I soloed the channel. Really didn't hear it live so tried the Aux out/in then to a channel with Effects 1 that had a reverb and it worked fine and I got through the night. I don't even remember why the band wanted to hear the effects on a track but for a throw and go it worked.
   Just now I tried Soft Patching Effects 1 to channel 32 and it worked fine. So with a pair or more of spare channels it would be easy to do as you say and save the latency as well. One of those things that is so rarely done. ( I don't remember why they even wanted it but oh well.. )
  Douglas R. Allen
« Reply #5 on: June 23, 2021, 02:01:54 pm »
  Douglas R. Allen
Douglas, thank you for confirming Brian's patch/routing.  I experimented with my X32 Rack at home and *thought* it worked but was unsure about the direct output > record final hop working.
Somehow they made something easy!  Thanks for checking.
JeffreyHague
« Reply #6 on: June 26, 2021, 02:32:48 pm »
Douglas R. Allen
Hey! I am the OP but had to set up a new account - forgot password, password reset methods failed, no response to messages from admins, etc.
Anyway, have you tried this? What I have seen is the multitrack recording follows inputs, not channels. I typically have my vocals on inputs and channels 17 through 21 and I dont change the inputs from show to show because there are other guys that work the club and its easier if everything stays the same. What I do for bands that I know the input list beforehand is create a show file that gets everything on 1 layer (if it will fit on 16 faders). The 1st time I tried the mutltitrack to SD I assigned inputs 17 - 19 to faders 14 - 16 and set it to record to 16 "channels". Once I dropped the files in to R.E.A.P.E.R., 14 - 16 were blank and no vocals got recorded.
JeffreyHague
« Reply #7 on: June 26, 2021, 02:34:06 pm »
Hey all!
Thanks!
Jeff
Thanks for the answers! I will try these and report back as soon as I am back at the club.
  • Old enough to know better
  • Audio Plumber
« Reply #8 on: June 26, 2021, 06:47:44 pm »
You never sent me a PM, unfortunately I am on vacation at the beach with little internet. I should be able to help you reset your password sometime in the next couple of days.
JeffreyHague
« Reply #9 on: June 27, 2021, 09:54:56 am »
I think I messaged Doug Fowler but cant remember and cant get in to check.
Thanks - just let me know when you have time and enjoy your vacation!
Page created in 0.035 seconds with 18 queries.
