Picking a Mic to Record Fireworks
<< < (6/7) > >>
Chris Grimshaw:
--- Quote from: Tim Weaver on June 14, 2021, 08:57:42 PM ---The 635A or any measurement mic is capable of picking up low freqs just fine. But large diaphragms (like a kick drum mic) do it a little better is all. In my mind having a seperate LF mic that can be tweaked and then blended in would be the way to go. Keep the natural unmodified sound from the omni mics and add in some boom from the Large Diaphragm mic. A D112 or a D6 or even something like an AT4040 or similar LD Condensor.
--- End quote ---
At close distances, you'll get the proximity effect boost in the low end, particularly in the 50-120Hz range.
A decent measurement mic will be flat to 10Hz (or below), even at larger distances.
I'm afraid I don't see the application for a D112 or whatever in this use case.
Chris
Tim Weaver:
It's so he can record and process the LF differently.
To Have a different option.
Will 2 measurement mics work? Yes. Absolutely.
Will 3 mics work? Yes. Absolutely.
Will 35 mics work spread out around the display? Yes. Absolutely.
It's all about options. For me, if I'm recording this for maybe youtube, or whatever medium for an advertisement or something, I would insist on having a seperate, mono source specifically for the low frequency content which I could limit, eq, and mix in to the (probably) untouched stereo track. This makes a world of difference on the end product where the listener will probably be watching this on an iphone or similar.
If the final product is just for OP to listen to on his high-end headphones with a decent front end, then sure. By all means, record a pristine and untouched pair of omni condensers and leave it alone.
Russell Ault:
--- Quote from: Jason Glass on June 14, 2021, 10:47:26 PM ---{...} Getting creative, my nutty mind drifts to one central mono EMX-7150 mixed with a distant ORTF pair for stereo ambience, also with band pass EQ. {...}
--- End quote ---
For many years the top choir recording engineer in the area used a standard C414 ORTF pair augmented with wider-spaced pair of factory-matched omnis (also hard-panned) all on the same tree, with the balance between the two pairs adjusted to taste based on the repertoire and the acoustics of the space (typically churches with pleasing-but-significant RT60s).
--- Quote from: Tim Weaver on June 15, 2021, 10:31:24 AM ---It's so he can record and process the LF differently. {...}
--- End quote ---
I must still be missing something; why can't you do this with just two mics? Break out each mic's LF, sum to mono (or pick one and discard the other; the only significant difference that's likely between the two will be timing, which won't be missed but likely will cause summing problems), then process to taste. I'm sure there are plug-ins out there that will do this automatically, but it wouldn't be hard to achieve with some basic crossover filters, either.
-Russ
Jeff Lelko:
I really appreciate all the great discussion here.  There are definitely several factors and approaches to consider!
I'm intrigued by the measurement mic approach.  One of the uTestMics for setting up an Audio Tools measurement rig has been on my casual wishlist for a while now, seeing as it's something I'd like to learn more about.  It looks like that mic hits all the specs minus having only a 108 dBA performance range.  I take it that's a deal-breaker for reliable use in close proximity to concussions?
That aside, I think the bottom line for me is that I'm looking for something simple and easy to just go place and forget.  Since in all of these cases my focus is on pyro and not audio, I want to adhere to the "KISS" philosophy and not over-complicate things as much as possible.  Maybe that'll change if I ever get paid to provide exquisite recordings of my firework audio, but until then I'm just looking for something simple but better than the GoPro mics that have reached their limit.  Thanks again!
Chris Hindle:
--- Quote from: Jeff Lelko on June 15, 2021, 10:47:41 PM ---I really appreciate all the great discussion here.  There are definitely several factors and approaches to consider!
--- End quote ---
It's SACRILEGE to talk like that around here........
You should know better....    ;D ;D ;D ;D
Chris.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
