Author Topic: I-Tech 6K replacement  (Read 1050 times)
Steve Hurt
  • Lab Lounge
« on: June 09, 2021, 11:05:38 PM »
I'm thinking of replacing my I-Tech 6K amps with newer amps
What are modern comparable amps that aren't I-Nukes and aren't unobtanium priced?
(I-Tech 6 K is 3000/w/ch into 4 ohms and has DSP built in - 2 rack spaces)
While I don't use 3kw/ch because that would blow breakers, the amps do make subs grunt really nicely compared to some other amps I've tried
(and for whatever reason, the 6K's have been a lot more trouble free than my older I-Tech 4K's were)
I will be plugging into edison outlets, often GFI protected  (I-Techs and GFI's hate each other for some reason)
Steve Litcher
    • MixMasters Podcast
Re: I-Tech 6K replacement
« Reply #1 on: June 10, 2021, 01:37:53 AM »
Have you looked into the QSC PL380? They’re pretty stout; we had a bunch of them when we ran passive JTR subs and were really impressed by them. Check with Mike Pyle for better pricing.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #2 on: June 10, 2021, 01:59:03 AM »
Powersoft T602 springs to mind. 1U, great DSP & control, 2500w/ch into 4ohm.
Oh, and you can directly limit the amp's mains current draw.
Chris
www.grimshawaudio.com
Benjamin Krumholz
« Reply #3 on: June 10, 2021, 07:34:18 AM »
You can find great deals on used Itech HD amps and 4 x 3500HD amps online currently.. You should be able to find an IT5000HD or IT9000HD for less than 2k.
https://www.ebay.com/itm/362500951611?epid=9012065003&hash=item5466bd8e3b:g:kBMAAOSw3s9fjcQg
John Halliburton
« Reply #4 on: June 10, 2021, 09:15:40 AM »
I've been very happy with my QSC PLD4.5 amps. Four channel, yet configurable to 1, 2, or 3, built in DSP, lightweight.
Best regards,
John
Matt Vivlamore
  • Lab Lounge
    • https://www.facebook.com/MeerkatSound/
« Reply #5 on: June 10, 2021, 09:26:39 AM »
I'd replace the original IT's with some Lab Gruppen PLMs or Crown Itech-HDs.
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #6 on: June 10, 2021, 10:06:30 AM »
Steve,
What speakers will these amps be powering?
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Helge A Bentsen
  • Oslo, Norway.
« Reply #7 on: June 10, 2021, 10:10:42 AM »
How many channels do you need and what  kind of DSP?
Powersoft X or T-series would be on the top of my list. Great DSP and flexibility.
Lab PLM if I wanted Lake Processing.
« Reply #8 on: June 10, 2021, 04:44:45 PM »
Chris
The nice thing about the Powersoft is the wideband supply.  You can use the same rack, PDU and amplifier.  If you are constrained by the mains have a configuration that would work properly on a 15amp 120v circuit (in the US).
My next rack is going to have three amps, two for the subs and one for mains.  I will put three edison inlets for venues with only 120v service and the appropriate twist lock for a 30amp 208-240v feed.  The distro will have a switch to transfer the inlet and the amps will auto range.  That's why I have my eye on the Powersoft.  They seem ideal for this config.
Steve Crump
« Reply #9 on: June 10, 2021, 08:09:50 PM »
+1 on the Powersoft T Series
Page created in 0.03 seconds with 18 queries.
