Author Topic: Two Honda Eu7000's  (Read 1022 times)
Stuart Hielscher
Two Honda Eu7000's
« on: May 23, 2021, 02:05:48 pm »
Hey everyone I'm a new member but have been a long time lurker for the past year or so. I'm sorry if this post is in the wrong section, please move it if so. A friend and I have put together a small sound system to host local EDM shows in our town. We plan on having an event outdoors here soon and we have access to two honda EU7000's. I personally own one and we tried testing everything on one last week and It did okay at low levels but noticed right away that it was spiking too much for just one generator with our setup. The setup:
4x JBL SRX828 SP Subs: AC Power Consumption (120V~): 2.2A (1/8th Power), 5.6A (1/3rd Power)
2x QSC KW122 Tops: AC Power Consumption 1/8 Power 100 VAC, 2.3 A • 120 VAC, 2.01 A • 230 VAC, 1.13 A
2x QSC CP8 Booth Monitors: AC Power Consumption 1/8th Power: 100 VAC, 0.75A -240VAC 0.31A
Pioneer XDJ-XZ Decks: Power Consumption 55W
All plugging into a Midas MR12 Digital Mixer: Power Consumption 30W
Running all of this off of one Honda EU7000 was okay at mid levels and the subs set at 0 db. As soon as we slowly turned it up we were watching the VA Reader on the generator go from 800 to around 5000. We turned it back down and quickly realized we didn't have enough power for this whole setup. We previously ran 4 Turbosound Nuq18b's with the same QSC setup and deck/mixer combo and had no problems with it running off of the 7000 so we figured we might as well see if it could handle our new subs. Unfortunately not, and I've done some research online and around these forums and everywhere I'd read advices against running two generators on one system. We have two Honda Eu7000's available to run all of this off of, is it advisable at all? Is there a safe way to properly do it? We have 10g cords to run from the generator to the subs, and can also run each sub on it's own cord. Should we try to split the system up right down the middle so the generators are pulling equal loads? We have an isolation transformer box, would that be helpful with running two generators? Do the generators need to be grounded to an earth rod? I've read conflicting information online about this with the 7000. I wish we could rent a bigger generator for the job but at this moment it just doesn't look like an option. Is it safe for me to run all of this off of two Honda Eu7000's?
« Last Edit: May 23, 2021, 02:12:39 pm by Stuart Hielscher »
Dave Garoutte
  • San Rafael, CA
Re: Two Honda Eu7000's
« Reply #1 on: May 23, 2021, 03:30:32 pm »
Huh,  I've run a couple of House music DJ events off my Yammie EF6300 with it at 30% draw (43 amps available).
4 TH118, 2 SM80, DNA20k4, 2 Yamaha dxr15 and dxs15 for mons.(DNA running 240v)
Not EDM, but not working hard at all.
« Last Edit: May 23, 2021, 04:54:16 pm by Dave Garoutte »
Steve-White
  • Fort Worth
« Reply #2 on: May 23, 2021, 03:50:39 pm »
One EU7000 should handle the load.  You tried it with one, have you tried the other EU7000?  I would do that to ensure both generators respond the same.
Then make changes if necessary.  Splitting the system between two generators will work fine.  Just be sure the chassis ground on both generators are well bonded electrically to one another.
Proper earth ground is recommended.
« Last Edit: May 23, 2021, 07:12:40 pm by Steve-White »
Paul G. OBrien
« Reply #3 on: May 23, 2021, 05:15:29 pm »
Quote from: Stuart Hielscher
These "electrical appliance" ratings are no help at all when sizing generators for audio equipment, as you have seen first hand but probably didn't understand you have to cover the peak demand from the equipment which means the rated amplifier power +10-15% because no amplifier is 100% efficient, class D amps are close however at 90% or so.
Probably only 4-5kw of audio there no suprise it worked.
Honda has parallel wiring kits for doing just this.
That is a good idea, I'd also suggest you use power distro cords that utilize the L14-30 240v outlet on the generators. By my count you have 8000w in subs alone which will get pushed for all they are worth, plus 1200w for the KWs and maybe a few hundred watts for the DJ monitors and kit, that should split up nicely into a pair of ~5kw(peak) loads on each generator.
« Last Edit: May 23, 2021, 05:37:05 pm by Paul G. OBrien »
Dave Garoutte
  • San Rafael, CA
« Reply #4 on: May 23, 2021, 11:07:11 pm »
I think the kit is only for the 2000 and 3000.
Doug Fowler
  • Saint Louis, MO USA
« Reply #5 on: May 23, 2021, 11:54:52 pm »
How are you distributing power to your various pieces?
Paul G. OBrien
« Reply #6 on: May 24, 2021, 09:08:18 am »
It's not the same simple kit used on the smaller gensets...
Mike Monte
    • My website
« Reply #7 on: May 24, 2021, 10:31:54 am »
There is a parallel kit for the eu7000is model:
https://powerequipment.honda.com/generators/models/eu7000is
Availability???
Also (FWIW) the parallel cables that I have for my two eu3000is' is:
"For use on EU3000is generators serial number 1034452 or higher"
The cables for the eu7000is series may also be serial number dependent...
...best to check before purchase.
« Reply #8 on: June 24, 2021, 12:56:27 pm »
Availability???
I have run 2 EU7000s with the parallel kit and it works great. No issues.
Year before last, I did all of the Atlanta Falcons pregame shows with the setup.  The area was 11 acres with a DJ playing hip hop type stuff most of the time.  A live band played a couple of times.
We ran everything off of the Hondas.  No lighting was used however.
doug johnson2
« Reply #9 on: June 28, 2021, 10:47:33 am »
I have been casually considering a parallel inverter set up for a while. But, it appeared that starting about two years ago the availability of the parallel kits for the larger generators dried up.  This seemed to be for all the manufacturers, not just Honda.
ยซ Reply #9 on: June 28, 2021, 10:47:33 am ยป
Page created in 0.028 seconds with 20 queries.
