Vented racks would be useful for devices that use passive cooling, eg effects racks or wireless racks, where there are no fans within the devices.
For devices that have directional cooling, paying attention to where the air is flowing is an important consideration.
QSC amps use the mentality that they will pull air from inside the rack and send it out the front as to not heat the internals of the rack enclosure. Others use the mentality that they pull cool air from outside of the rack and send it inside, assuming that you have proper ventilation designed to release the hot air out the backside of the rack.
Some equipment pulls air from the left side of the rack and exhausts on the right side, and vice versa.
Essentially, what it boils down to is that there's no one standard that everyone uses. When building racks, this all needs to be taken into consideration on how to best assemble things so that stuff stays properly cooled. This may mean separating devices that use different cooling flows so that they play together nicely with their partners.
In the case of your matching amps, more airflow is definitely better, but to be effective, that airflow needs to go THROUGH the amps, not through that open space. A solid cover helps guarantee that the airflow goes in the amps and out the back and doesn't end up recirculating through the space and go back into the amp.
