Author Topic: Danley BC215 Directivity  (Read 1580 times)
John Hiemburg
« on: May 07, 2021, 07:59:19 AM »
Good morning,
Looking at a design for a new room, and my first intention was 4 TH118XL's in an end-fire configuration (flown). This checks the boxes for a: Total output, b: Some level of directivity; c: Budget.
However, a pair of BC215's would check the same budgetary and output boxes (Direct modeling showing this a little more powerful than the 4 TH's). Just curious about any real world experience or measurements of the actual directivity for a pair of BC215's configured as a pair like recommended.
Thanks in advance.
John Halliburton
  • White pointy beard, knows zip...about chicken.
Re: Danley BC215 Directivity
« Reply #1 on: May 07, 2021, 09:47:31 AM »
I believe the BC215 really need a boundary to perform to spec, and you state the TH118XL would be flown, so you're likely losing out on some performance going with them.
Best regards,
John
Caleb Dueck
« Reply #2 on: May 07, 2021, 07:57:13 PM »
Good morning,
Thanks in advance.
How about a single BC415?  Or is that too tall?
Art Welter
« Reply #3 on: May 08, 2021, 06:01:08 PM »
John,
We met about a decade ago when delivering stage curtains you purchased, around the time I tested the directivity of tapped horns (TH), bass reflex (BR), and front loaded horns (FLH), and a TH with an increased boundary coupling area (BC).
Yesterday morning, before seeing your post had thought of posting to see if anyone had measured the directivity of TH compared to other designs in a large open space, as my test was flawed do to proximity to reflective boundaries:
https://www.diyaudio.com/forums/subwoofers/184982-tapped-horn-directivity.html
Though flawed, the test showed that the TH had a much higher directivity index (DI, or forward gain) than FLH and BR, and the BC additionally increased the DI.
Tom Danley current BC (Boundary Coupled) FLH designs are similar to his earlier BDEAP (Boundary Dependent External Air Path) designs, though not dependent on corner boundaries to “be deep” in low frequency response.
Some explanation of the concept :
https://forums.prosoundweb.com/index.php?topic=75746.0
In that thread, on 4/6/2005 Ivan Beaver wrote he measured -10dB at 90 degree off axis around 40-50 Hz with the BDEAP in a quad stack.
Impressive, though a single 1/3 octave and a single off axis measurement don’t provide enough information to make a decision.
Unfortunately, DSL’s specification sheet claim of “delivering actual directivity” tells even less.
Fulcrum Acoustic provides axial sensitivity response curves for their passive subcardioid designs, which have around -10dB 180 degree response. I’ve walked around the CS118, and can confirm the specs hold up in the ‘real world”.
Without seeing axial measurements for the DSL BC215 subwoofers, I’d tend to favor the flexibility that four TH118XL in a “staircase” end-fire array could provide.
One could “dial in” the angle and frequency that needs most attenuation with the  end-fire array, while the axial response and fixed frontal size of the BC may not work well in the location it is relegated to.
As to direct modeling showing a pair of BC215 a little more “powerful” than four TH118XL, from the spec sheet it appears (as usual per Hofmann’s Iron Law- Low, Loud, Small, pick two..) that the sensitivity is due to the higher and steeper rolloff (and Fb/Fc) of the BC215.
Both are rated at 108dB sensitivity, but the BC215 is 2 ohms, the TH118XL is 4 ohms. Adjusting their sensitivity from 28.3v at 10 meters to 1watt/1m, additional cabinets added each powered by one watt)
BC215: 30Hz@94dB, 100Hz@107dB
BC215 x2: 30Hz@103dB (+7), 100Hz@112 (+5dB) from single to dual
TH118XL: 30Hz@96dB, 100Hz@103dB
TH118XL x4 : 30Hz@108dB, 100Hz@115dB (+12 dB estimated from specifications)
The frontal boundary area of two BC215 (45” x90”) and four TH118XL are equal.
On 6/8/2006 Ivan posted measurements of 1, 2 and 4 DSL TH115 at 10’ (feet). The SPL from stack of four evidently clipped the test rig above 70Hz, causing a flat line, but below 50Hz an increase of around 2dB forward directivity over the +12dB expected can be seen. If that test is indicative, a quad of TH118XL may have a few dB LF on axis over the single than estimated.
The recommended 30Hz BW24dB HP for the BC215 compared to 26Hz BW24dB HP for the TH118XL would increase the level disparity at 30Hz.
40-50 Hz output should be higher with a pair of BC215, 30-40Hz output should be quite a bit more with four TH118XL.
Art
« Reply #4 on: May 10, 2021, 03:34:05 PM »
The numbers in Direct for the different BC configurations come from actual measurements of the different configurations (1,2 4) as measured outside on the ground without reflections.
They are not simulated.
One way that I like to look at sub directivity (in direct) is to put a mic in front and another behind the subs (at the same distance) to get an idea of the difference.
Here are the actual measurements from the polars
As you can see, the directivity gets greater as you go higher in freq, as would be expected
John Hiemburg
« Reply #5 on: May 10, 2021, 04:14:04 PM »
Great, thank you Ivan!
In my case - flown subs (about 25' from the floor, 10' from the ceiling) - would you expect better directivity from the 4 TH118XL's configured as an end-fire array or two BC215's or a single BC415?
Or am I thinking about this wrong? Each of those three configurations would be pretty close in cost all in. The single BC415 is an easier rig (one big piece rather than 4 or 2), and don't have to worry about spacing, delays, etc..
Thanks for your help.
« Reply #6 on: May 11, 2021, 08:17:08 AM »
Here is some things to consider, when you are flying the subs, how important is the rear cancellation?
You can get greater rear cancellation from a cardioid setup vs endfire, but endfire has overall better sound quality.
But if rear rejection is the main concern, you can "let the quality go".
Also when dealing with directional subs (from the electronic cancellation approach), you also need to be mindful of other boundaries behind the subs, as these can nullify any attempt and even make the sound out front worse.  A sub with natural directivity (meaning just less energy going to the rear, but not by cancellation by other drivers) will not suffer from those boundaries as much.
John Hiemburg
« Reply #7 on: May 11, 2021, 10:34:35 AM »
Great, thank you. The rear cancellation isn't the main consideration, just getting the low end further out front. In other words, I'm only looking at directionality for the sake of getting my 'bass dollars' into the seats.
Chris Hindle
« Reply #8 on: May 11, 2021, 12:39:16 PM »
Leviathan?   ::)
Chris.
« Reply #9 on: May 11, 2021, 04:59:42 PM »
Any steerable sub configuration will result is LESS forward output.
If you want the most forward output, then just get the proper sub or subs with the output level you need at the frequencies that you need.
There is a falicy that directional subs are louder than the same number just "piled up", and the reason (however SO WRONG) is that the rear energy is folded back to the front.  That is completely WRONG.
Page created in 0.042 seconds with 18 queries.
