Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > DJ Forum
Has anyone every used Full Range Speakers as a Subwoofer?
<< < (3/3)
Mike Henderson:
--- Quote from: Mike Caldwell on May 06, 2021, 10:23:43 PM ---I would be looking into why the sub is not working before these speakers meet the same fate.
--- End quote ---
It is the cabinet's Speakon connector which is the issue. I will wait on my sound system bud to come across to fix it and at the same time we will look into the possibility of using the EV Full Range as subs.
I tested again and I am getting the same bass now everywhere in the room with the EV's having them at the back wall and facing them towards the side wall.
Mike Henderson:
--- Quote from: Mike Henderson on May 07, 2021, 10:07:07 AM ---It is the cabinet's Speakon connector which is the issue. I will wait on my sound system bud to come across to fix it and at the same time we will look into the possibility of using the EV Full Range as subs.
--- End quote ---
One last thing on this speaker facing the side walls issue guys. Please see attached pic of the back wall of my Garage. I am thinking of trying the EAW sb1000 sub in the same position but right now those are the EV's showing on the bottom of the pic facing sideways between the 2 storage shelves. As you can see there is some space like maybe 10" on each side facing the shelves. Now if I were to place the EAW sub in that same way there would hardly be any free space on either side so might this be safe please?
https://i.postimg.cc/tgHPHHZq/IMG-2777.jpg
Tim Weaver:
I'm gonna go out on a limb here and guess that you aren't really hitting the volume levels where a true concert sub (SB1000) is actually needed, AND you are likely listening to music that doesn't need super low frequency response. Rock, country, pop, etc all peters out below 60hz pretty quick.
The reason the Humiliator sounds louder is because it is. It is a DJ cabinet and as such has a bump in the response right around where you'd want it for pop music. This makes them sound better than other speakers when you listen to them at Guitar Center. It is also useful if, say, you're a wedding DJ and use a pair of these and no subs. That would be plenty adaquate.
The Humiliators are also quite a bit more efficient than the big, long throw, giant magnet sub drivers in the SB1000. So they'll be noticably louder at 100 watts than the SB. The difference in the two is that the SB1000 could take 2000 watts, properly processed and limited all night long at a rap concert and not break a sweat. The humiliators would be a smoking pile of ash if you asked that of them.
Mike Henderson:
--- Quote from: Tim Weaver on May 10, 2021, 04:55:53 PM ---I'm gonna go out on a limb here and guess that you aren't really hitting the volume levels where a true concert sub (SB1000) is actually needed, AND you are likely listening to music that doesn't need super low frequency response. Rock, country, pop, etc all peters out below 60hz pretty quick.
--- End quote ---
That's a good explanation, thanks!
Tim Weaver:
--- Quote from: Mike Henderson on May 10, 2021, 06:37:14 PM ---That's a good explanation, thanks!
--- End quote ---
No prob.
More than a decade ago I worked at a big university. We had ancient Altec Lansing A5 clusters left, center, and right. It was 4 15" drivers in each cluster and since we hardly ever used the center I used to low pass it just to give me that extra little bit of thump for those shows where I didn't really need to roll out the subs and amps. It worked great, but you need to know the limitations of the gear and work within that.
That's also the place where we named our pair of Eliminators the "Humiliators". It was appropriate at the time. Still is probably.
Navigation
[0] Message Index
[*] Previous page
Go to full version
