Author Topic: Help with Yamaha EMX-5000-20 Powered Mixer  (Read 1552 times)
Dominik Varitis
« on: April 30, 2021, 06:27:09 AM »
Hallo everyone,
I have a Yamaha EMX-5000-20 Powered Mixer, a pair of JBL JRX118sp Powered Subwoofers and a pair of JBL SF 15 Passive Speakers (8 Ohms each).
I have read the manual of the Yamaha Mixer about ten times, but I can't figure out, hoe the internal power amps works.
In the manual it says :
Set this as appropriate for the size of the room or
the input capacity of the speakers.
• 500W + 500W
The two internal amps will produce a maximum
of 500W + 500W/4W.
• 300W + 300W
of 300W + 300W/4W.
• 100W + 100W
of 100W + 100W/4W.
Can I still use my 8 Ohms Speakers? If yes which of the three setups should I use (100W, 300W or 500W)
The Speakers work between 250-1000 W.
I also don't understand, if the internals power amps send the signal only to the Speaker Outputs?
I also have a Crown XLS-602 Power Amp and a Behringer Super-X Pro CX2310 Crossover. Do I really need them or could I just use the Yamaha to connect my 4 Speakers (2 Subs+2 Speakers)
Every recommendation is welcome  :) :)
Keith Broughton
  • Toronto
Re: Help with Yamaha EMX-5000-20 Powered Mixer
« Reply #1 on: April 30, 2021, 06:58:04 AM »
I'm sure you will get some help when you log in using your real name.
Dominik Varitis
« Reply #2 on: April 30, 2021, 07:13:03 AM »
I am really sorry, I am new here. I changed the name to my real one  ;)
Kemper Watson
  • Woodstock GA
« Reply #3 on: April 30, 2021, 08:03:18 AM »
The internal amps will produce power determined by the ohms it encounters .The lower the ohmage the higher the power. It doesn't need to be switched anywhere. The power comes from the output on the back panel only. I would connect the subs to the sub out. It is a full range out but the subs have a built in xover and will only reproduce the lower register. there are four aux outs that can be run into other power amps/powered speakers for monitor use. This is my take from a 15 minute read through the quick start part of the manual.  Hope it helps
lindsay Dean
« Reply #4 on: April 30, 2021, 01:14:02 PM »
Check the owner's manual on adding a sub
You would not run the tops full range .
you would have use the consoles built in crossover
or patch your own in through the preamp and out
 it's explained in the manual on page 28 https://manualmachine.com/yamaha/emx500020/697852-user-manual/
« Last Edit: April 30, 2021, 01:17:54 PM by lindsay Dean »
     and Pray for higher guidance
Mal Brown
« Reply #5 on: April 30, 2021, 04:10:50 PM »
I had the 5000-12.  I don't recall an internal cross over.  I ran ST Out to a crossover, then to a power amp and used the onboard amps as monitor 1 and 2.  Could just as easily use powered sub.  You might have to,research the lpf of the crossover in the sub and mimic that with the external crossover.  Instead of using an external power amp, you could bring the mid's and highs back in the pwr amp in jacks.   That board had pretty flexible i/o for an all in one...
Bass player, sound guy.
FB Gorge Sound and Light
FB Willyand Nelson
FB SideShow
lindsay Dean
« Reply #6 on: April 30, 2021, 07:10:51 PM »
look at the manual its a setting...........
Page created in 0.035 seconds with 21 queries.
