Author Topic: Dante to AVB interface?  (Read 643 times)
Kent Clasen
« on: April 21, 2021, 08:41:34 am »
Hello!
Does anyone have any experience with running Dante mixer into a speaker DSP that uses AVB input?
I see the PreSonus interface [which looks inexpensive] but have never used one...
https://www.presonus.com/products/AVB-D16
TIA.
Robert Healey
Re: Dante to AVB interface?
« Reply #1 on: April 21, 2021, 10:49:03 am »
Hello!
TIA.
Kent,
The new Biamp TC-5D is designed for this very application:
https://support.biamp.com/Tesira/AVB/TesiraCONNECT_TC-5D
EDIT: I think this only works as a Dante endpoint in a Tesira system. Is the DSP a Biamp?
« Last Edit: April 21, 2021, 10:52:23 am by Robert Healey »
Kent Clasen
« Reply #2 on: April 21, 2021, 11:14:47 am »
Kent,
Hi Robert!
Long time no talk...
Not Biamp- it is a Meyer Galaxy.
Russell Ault
  • Edmonton, AB
« Reply #3 on: April 21, 2021, 05:27:15 pm »
That Presonus box (first time I've heard of it) is remarkably inexpensive for its capabilities and might be worth a try. The other option is something that does Dante to AES3 (like a few Avios) and skip AVB entirely.
If you do go the Dante-to-AVB route, just bear in mind that the networking infrastructure requirements for AVB are very different from Dante (or really anything else).
-Russ
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #4 on: April 21, 2021, 05:42:30 pm »
-Russ
To go right out and say it...you really shouldn't be running dante and AVB on the same network.  That said, i have, on my bench, gotten dante and cobranet (AVB's grampa) to coexist happily on the same network, but would never deploy a configuration like that in the wild though.
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
« Reply #5 on: April 21, 2021, 08:35:28 pm »
You are a magician, David.  Any hints?
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #6 on: April 21, 2021, 08:54:20 pm »
Oh man,  I got called out.  It's been some time, but i do recall the usual dante settings, and then I think I was doing MAC address filtering to block the cobranet clock (and any multicast bundles, each multicast bundle is a different broadcast MAC) from the dante side. I only have enough cobranet devices laying around to test probably 8x8 on that side, and around 16x16 on the dante side, so it wasn't a large scale test by any means.
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
« Reply #7 on: April 22, 2021, 01:09:14 am »
MAC address filters and multicast management.  Got it!
This is for my own amusement since we still have a couple Cobranet devices.  I expect to spend some time with Wireshark.
Too many dangerous critters in audio... sharks and snakes (some are cobras).
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #8 on: April 22, 2021, 09:35:39 am »
I plugged in an old switch I used back in the day when I was working with one of those cobranet E-snakes at a local venue.   I configured the last two ports on that switch to block cobranet so I could safely connect an access point.   If you look at the attached photo you will see the MAC's that I blocked.   The first 8 should correlate to multicast bundles 1-8.  The last two should correlate to the clock.
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Kent Clasen
« Reply #9 on: April 22, 2021, 11:25:11 am »
While the PreSonus does look like a good price, I would rather go with something I know will work and be reliable. I think Dante to AES is the easiest / simplest way to go.... Looks like there are several available 2ch-16ch interfaces. I need 8ch so good to go.
I kinda wonder if PreSonus has this as a bit of a loss-leader due to their mixers are AVB but they have Dante speakers...but may be worth testing one out sometime.
Thanks everyone for the ideas and info!
« Last Edit: April 22, 2021, 12:34:07 pm by Kent Clasen »
Page created in 0.048 seconds with 18 queries.
