Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Lighting Forum
DMX controlled system power? DMX Mains Relays?
<< < (4/4)
Scott Hofmann:
--- Quote from: Tim Weaver on April 17, 2021, 02:51:35 pm ---
This room will have house lights and stage lights controlled by DMX. Chamsys MagicQ PC at FOH then run through a Fleenor Preset 10 for house light control when the console is off.
Having dmx control of the relays would mean anyone could come in, hit Preset 3 on the wall control and pull up a complete scene for stage and house. This would be super useful for funerals and wedding, largely meaning I don't have to come in for these things.
I won't get any cooperation with the ladies that organize these things if they have to upstairs, into a dark closet, ka-chunk a big disconnect, then go to the console, boot it up, and then recall preset 3......
--- End quote ---
So what you are trying to do is DMX-control a main disconnect instead of individual circuits? What is the amperage? Single or three phase? I think LynTec and ETC have up to 30A 3-phase DMX-controlled breakers but for more than that you may need a real electrician and some kind of contractor that is controlled by a pilot relay under DMX control.
Tim Weaver:
--- Quote from: Scott Hofmann on April 18, 2021, 10:32:22 am ---So what you are trying to do is DMX-control a main disconnect instead of individual circuits? What is the amperage? Single or three phase? I think LynTec and ETC have up to 30A 3-phase DMX-controlled breakers but for more than that you may need a real electrician and some kind of contractor that is controlled by a pilot relay under DMX control.
--- End quote ---
What I'm trying to do is consolidate and clean up the supply side of the lighting rig. This has two driving forces:
A) I'm burning up PSU's right now because the rig is left on 24/7
B) Half the circuits come from the stage-end of the room and half the circuits come from the FOH end.
The weird power routing was a holdover from the days of hot lights. They didn't have enough service on the stage end of the room so they pulled from a panel in the back to supplement.
Today everything is LED and I'd like to pull all my lighting power from the back of the room, because the panel by the stage is only 100 amps, and I run the audio from there and we now have (and are expanding on) LED screens. I want to give that stage side panel to audio and video and I'll take lighting from the panel in the back.
LX Saga part deux. All the power that feeds the branch circuits for lighting currently runs through some household light switches. Some of those switches are located in a cage, inside a room by the stage and the rest of the switches are upstairs on a balcony above FOH. There are 13 or 14 switches total at opposite ends of the room.
I want to get rid of all of that mess and just have power pulled out of the 100 amp panel in the FOH side of the room which comes down to a Jbox behind the lighting desk where I would install contactors which are controlled via DMX. This way when someone hits the switch panel on the wall the house lights come up like normal, and the stage lights can also be controlled via simple presets.
Whether that panel behind FOH is fed via branch circuits or it is a whole disconnect on it's own is immaterial. I just want it switched via DMX.
Scott Hofmann:
The ETC Echo or Sensor IQ DMX-controlled breaker panels look like good solutions. Either can be fitted with a main breaker although that is not under DMX control. Both have up to 48 breaker slots per panel.
Caleb Dueck:
--- Quote from: Tim Weaver on April 18, 2021, 10:51:16 am ---What I'm trying to do is consolidate and clean up the supply side of the lighting rig.
--- End quote ---
Lyntec if you want to integrate into the electrical system.
https://lyntec.com/lcp-lighting-control-panelboards/
Lots of small options others have mentioned above.
Stephen Swaffer:
I installed a Northlight 4 channel relay board about 3 years ago on the houselights in our church and it has worked flawlessly (except when someone insists on using wireless DMX instead of wired but that's not the Northlight's fault).  Incidentally, I set this installation up with the lights on normally closed, so the DMX actually shuts them off-not turns them on.  That allows the original switches to work normally anytime the DMX controller is off.
Navigation
[0] Message Index
[*] Previous page
Go to full version
