Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Lighting Forum
DMX Light react to Audio Output
<< < (2/3) > >>
Jeff Lelko:
--- Quote from: Dave Garoutte on April 02, 2021, 12:47:26 pm ---Never seen anything that took an audio input.
--- End quote ---
Believe it or not my little Behringer LC2412 can take a 1/4" audio input and has a sensitivity fader for sound-to-light triggering.  They're out there, but it's an uncommon feature.
Alex, if you're not satisfied with your light's sound-to-light function or auto mode you'll need to buy a DMX controller.  There are ways to set up what you describe but your expectations need to be very low in order to be satisfied with the result.  It's a fair bit of work and money to set up something that ultimately won't be much better than what the light can do by itself.  Better sound-to-light can be accomplished with MIDI triggering or plugins with DJ software but increase complexity by another order of magnitude.  What exactly are you trying to accomplish with this?
Rick Earl:
--- Quote from: Alex Reid on April 02, 2021, 06:18:49 am ---Hi,
Ive purchased a Equinox Swing Batten LED light which has DMX Out / IN. Im wanting the light to react to the audio coming either from A) My mixer output or b) laptop audio output.
Please can anyone advise how to do this?
Cheers,
Alex
--- End quote ---
This might do what you're asking. https://www.ledlightingproducts.co.uk/sound
Paul G. OBrien:
There are lots of DMX controllers that can take a line level audio input and use it to trigger lighting, the one thing none of them will do however is automatically control the lighting with no pre programming. Basic hardware controllers use the audio signal to advance scenes or chases that you have programmed, software controllers can do much more complex things with the audio signal including custom timeline based effects specific to individual tracks, but again there is a lot of work that has to be done ahead of time to get good results.
Alex Reid:
Hi All,
Many thanks for your input, as you can tell Im new to the lighting scene ha ha!
Basically I'm starting to do live DJ Streams online with video, however because of where I live I can hardly "blast out" the tracks to a point where sound to light mics on the light would react with any decent correlation.
I have learnt to mix and play my sets without the need to play them "out loud". Instead I stream the master output to my laptop which then streams the audio live to the feed online. Therefore even though no sound is playing at where I am, the music is still playing (if that makes sense). That obviously creates problems of the lights reacting to the sound, as there is none playing out loud!
I have read somewhere (you may laugh at this Im not sure the legitamcy of this), but to get an old pair of cusioned headphones and stick one of the headphones (l or r) over the mic input on the light for the sound to light fixture, creating an air tight seal. This may not be perfect, but I presume A) It will react more to what Im playing from my mixer and B) it will react better than it just in silent mode?
Secondly, I have purchased a cheap DMX Controller to see what I can come up with it is a cheap:
IBIZA 16-2320 LC12DMX DMW Controller - 12 Channel DMX controller, and the light Im wanting to use it with is the Equinox Swing Batten LED which says DMX channels: 6/12 or 16 selectable. Have I bought the right equipment even if it is just to "mess about" to see what I can come up with?
Any more thoughts?
Appreciate all your help.
Cheers,
Alex
Jeff Lelko:
--- Quote from: Alex Reid on April 03, 2021, 07:58:39 am ---Secondly, I have purchased a cheap DMX Controller to see what I can come up with it is a cheap:
IBIZA 16-2320 LC12DMX DMW Controller - 12 Channel DMX controller, and the light Im wanting to use it with is the Equinox Swing Batten LED which says DMX channels: 6/12 or 16 selectable. Have I bought the right equipment even if it is just to "mess about"?
--- End quote ---
Well, maybe...  As youíve already noticed your controller is only 12 channels, so youíll have to use the light in 6 or 12 channel mode for things to work properly.  That being said, it doesnít look like your controller is programmable in any way.  As mentioned above, you typically program scenes and chases into the controller that get cycled by audio.  I donít see how this controller will work for what you need.
Sound-to-light usually picks up on bass more than anything else, but putting a headphone over the lightís mic is probably worth a try.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
