Pages: 1 2 [3]   Go Down
Author Topic: Strange hum in audio  (Read 1756 times)
Bill Jones
Re: Strange hum in audio
« Reply #20 on: March 20, 2021, 08:58:18 PM »
Thanks for all the input. You guys are the best.
I think the fiber HDMI cable in the attic sounds like the best option for me. The extractor at the sound board also sounds like to way to go.
Thanks again.
Bill Jones
« Reply #21 on: March 21, 2021, 07:37:41 AM »
The hard part in installing the fiber HDMI will be telling the young man that crawled into the attic that he has to remove the wire he just installed a week ago, and then put in another wire.  ;D
raymondsoly
« Reply #22 on: March 21, 2021, 11:25:43 AM »
And then tell him you were kidding  ;D, and that he could just use the existing cable as a pull line for the new cable instead..... 8)
Ray
Russell Ault
  • Edmonton, AB
« Reply #23 on: March 21, 2021, 03:22:28 PM »
{...} and that he could just use the existing cable as a pull line for the new cable instead..... {...}
Risky business pulling fibre outside of conduit!
-Russ
raymondsoly
« Reply #24 on: March 21, 2021, 06:15:45 PM »
-Russ
perhaps no riskier than having a young person crawl in there ?
Ray
Bill Jones
« Reply #25 on: March 22, 2021, 06:33:10 AM »
-Russ
Is the fibre HDMI fragile, more so than any other wire? Will there be a problem bending it around corners?
Dave Garoutte
  • San Rafael, CA
« Reply #26 on: March 22, 2021, 01:58:06 PM »
The manufacturer should spec a minimum radius.  The cables are more delicate than an xlr, but not a lot.
Helge A Bentsen
  • Oslo, Norway.
« Reply #27 on: March 22, 2021, 02:35:45 PM »
IME HDMI cables and network copper cables tend to be a lot more fragile than a fiber cable.
Russell Ault
  • Edmonton, AB
« Reply #28 on: March 22, 2021, 03:38:30 PM »
The usual warning with fibre is that bending it below its spec'ed minimum radius even once can cause permanent, it-doesn't-work-any-more-style damage (that very few people can fix), which is why pulling it can be risky. Other than that, fibre tends to be pretty durable, and (depending on the fibre) it can have significantly better tensile strength than copper-based cabling (which is why pulling it through properly-shaped conduit is no big deal).
-Russ
raymondsoly
« Reply #29 on: March 22, 2021, 05:09:51 PM »
The weakest links here might actually be the attic type and /or the 2 x 50'  hdmi, which won't offer much pulling power at the coupler...
Ray
Pages: 1 2 [3]   Go Up
Page created in 0.026 seconds with 17 queries.
