Author Topic: Video Streaming Novice | From Camera to Live Streaming | What am I missing?  (Read 1464 times)
Daniel Krueger
Hello again everyone! I was one of many sound techs that were tasked with getting live streams set up for their church amidst COVID. I received lots of good advice from this forum when we were experiencing horrible sound issues and now we have crisp, clean, and beautiful audio from the changes that we made based on those suggestions.
So here's my next dilemma (that's a bit dramatic).
I am a camera/video novice
Our Gear
We have two cameras at the moment and one input from our Powerpoint computer.
Both cameras can output 1080p via Mini-HDMI to HDMI. (I can get you the camera models if that helps, they are simple camcorders).
We use HDMI-USB converters to connect to our PC (Intel Core i7-10700 CPU @ 2.9GHz, Geforce 1650 - I think).
Our budget didn't allow for the top-of-the-line models so two of these are the "next best thing/budget" and another one is a "super budget" option that actually does better than the other two for whatever reason. (Note: I think this may be my problem but I have no idea).
Our live streaming software of choice is VMix.
Which has been setup in every way I can tell, to take inputs of 1080p and output in every way 1080p.
Our Issue
From Camera to VMix
As I said before, I believe everything is setup to input and output 1080p, but the input views clearly look sub-1080p. I have not figured out any option in the software to adjust it anymore. It is also quite grainy which can be helped by making sure there's more light (but we can only do so much).
From VMix to Facebook
Now I know that Facebook, by default, caps live stream quality at 720p. I know we are not reaching that quality though when our stream is up even though it will say it is. (Potato quality some would say). Visit https://www.saintmarkgr.org/live-streams-recordings/live-stream/ for samples of what I'm speaking about.
What are we doing wrong? What are the major issues we should inspect first? Any advice is helpful!
All in all, this is not an urgent issue, but something we'd like to get to sooner than later. Right now, it looks GREAT on a phone screen, but size that up to a 65" TV like we've had some of our members do and that GREAT turns into "It'll do".
I will get a detailed list of exactly what our equipment is.
Thanks everyone!
_______________________
Dan Krueger
Saint Mark Lutheran Church
Dave Garoutte
  • San Rafael, CA
I suspect the main problem is you're feeding too much bandwidth into the USB on your PC.
Software streaming can be problematic also.
Look into the BlackMagicDesign ATEM Mini series switchers.
Depending on what you're doing with VMix, it might make sense.
The Mini Pro will take your 4 inputs (2 cams, laptop and PC) and stream directly to facebook via its internal hardware.
It will do overlays and PiP effects.
Plenty of tutorials and testimonials on youtube.
« Last Edit: January 10, 2021, 05:50:55 pm by Dave Garoutte »
richard_cooper
I'd have a look at these HDMI-USB devices. I've got quite a few of the unbranded ones, which are fine for my use but not exactly good quality. They all seem to down sample what ever the input is to 720p and also do weird things to colour. One I've got can be set to capture in 1080p but looks like it's still down sampling, and the subsequently re-up sampling (badly). I've also got Black Magic mini recorders that work as expected, but they require thunderbolt and cost somewhat more.
I'd second looking at the ATEM Mini Pro.
Dan Richardson
  • southern Vermont
    • NotTooLoud
Please do. When troubleshooting, start with the source.
Mike Caldwell
  • Covington, Ohio
The ATEM Mini series is great but they do not work well with a mix of different input resolutions.
Dave Garoutte
  • San Rafael, CA
It sounds like the OP is 1080p all the way.
Mike Caldwell
  • Covington, Ohio
I was thinking the computer input could be the wild card.
Ed Merritt
I reviewed a video from Jan 31 and it appears to be a low bit rate stream. What bit rate is your livestream ? This can be checked on the Stream button, down at the bottom of the screen.
What is your internet connection like? Have you measured the speed?
The HDMI->USB capture cards will work fine for two cameras - I've done it many times using a laptop with nearly the same specs as your PC. I use the Magewell capture cards and they are champs. No additional software drivers needed. Just plug in and they work.
The vMix video windows should not be used to judge the picture quality. By design they are low resolution so as not to take system resources away from the stream. Although latency will be an issue, use an external monitor or smart TV to view your livestream.
I've been using vMix since 2015 to do some corporate streaming work and it's been very good. I volunteered to provide livestreams of the church Masses during the arly days of the lockdown. Here's an example of a Mass for Lent last April: https://youtu.be/GfcXDk6jWl8 .Shortly after this, we installed a Panasonic PTZ camera so no more two camera streams.
Daniel Krueger
Alright, it's been a while everyone but here's some more info on our gear:
Main Camera: https://www.amazon.com/dp/B072L4BF9T/ref=cm_sw_r_oth_api_glt_fabc_5HE8Y3EX15DAEZZ18WAA?_encoding=UTF8&psc=1
We have another camera that we used for a short time, but very similar quality to our main.
Capture Cards: https://www.amazon.com/Capture-Broadcast-Streaming-Grabber-Converter/dp/B0779ZJZX3/ref=sr_1_20?dchild=1&keywords=usb+capture&qid=1613581940&sr=8-20
Capture card that we tried out cause it was cheap but then started to glitch out on us: https://www.amazon.com/gp/product/B08H273TZ8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Thanks!
Dan
Our Gear
Our Issue
From Camera to VMix
Thanks everyone!
Dan Krueger
Daniel Krueger
Thank you!
I will check the bitrate and internet connection speeds tonight.
Thanks for the input on the video windows. I'll hook up an additional monitor to view the live stream simultaneously.
Any other feedback on vMix? Anything specific to consider when hooking up a new camera?
Thanks again!
Dan Krueger
Page created in 0.025 seconds with 20 queries.
