Author Topic: Balanced -> Unbalanced and CMRR  (Read 1184 times)
Peter Kowalczyk
« on: November 03, 2020, 10:14:36 PM »
I have a situation where I need to take an unbalanced -10dBu signal and send it across a building to another unbalanced input.  250' or less, probably more like 150'.
I had planned to use a passive Summing / Balancing box at the source end, and another Balanced -> Unbalanced device at the receiver end.  The Audio Control BLX-10 transciever looks like it would do the job, but it doesn't appear to be available anywhere.
It occurred to me that I could just take one leg of the balanced signal at the receiver, but then I realized that this would negate any possible CMRR benefit from using a balanced line.
Then I started wondering if ANY *passive* balanced -> unbalanced receiver would give a CMRR benefit.  My instinct says that it wouldn't; you'd need an active receiver for that.
What would you use?
Mike Caldwell
  • Covington, Ohio
Re: Balanced -> Unbalanced and CMRR
« Reply #1 on: November 03, 2020, 11:18:39 PM »
Look at Radio Design Labs aka RDL.
They have a quite a few unbalanced to balanced interfaces/converters both passive and active and
balanced to unbalanced interfaces.
I would look at using an active unit at the sending end and a passive unit at the receiving end.
Keith Broughton
  • Toronto
« Reply #2 on: November 04, 2020, 06:23:39 AM »
I have done something similar with a Rapco Isobox at each end.
It's a transformer so you maintain CMMR over the long distance run and just wire the in and out sides for an unbalanced line. (short pin 3 to pin 1 and use 1 and 2)
« Reply #3 on: November 04, 2020, 08:26:47 AM »
+1 transformers
« Reply #4 on: November 04, 2020, 08:37:49 AM »
One thing you need to be a little concerned with is the level.  Small transformers will saturate with higher levels.
Look for a +4 dBu transformer and you should be fine.
I used to have a pile of old Altec octal plug in transfomers that I have used in all kinds of situations regarding unbalanced to balanced and vice versa configurations.  They always did the job.
Peavey used to make them also for the balanced inputs into the older amplifiers.
Just don't use a mic level transformer.
Transformers are also good, because the provide physical isolation.  A VERY GOOD thing.
Steve-White
  • Fort Worth
« Reply #5 on: November 04, 2020, 04:21:18 PM »
Source Active > Destination Passive
« Reply #6 on: November 04, 2020, 06:20:32 PM »
Why?  With decent quality transformers you should very little loss.
But there is nothing wrong with your statement.  To me, the big thing is having physical isolation at either end
Mike Caldwell
  • Covington, Ohio
« Reply #7 on: November 04, 2020, 07:22:25 PM »
In my original post I was thinking that same thing just to bump up the level. At the destination/input end
a good ole fashioned transformer.
That all said a couple hundred feet is not that far and we send a much lower level mic signal that far
down a snake cable all the time or maybe not so much now in the world of digital.
Peter Kowalczyk
« Reply #8 on: November 04, 2020, 08:07:17 PM »
Thanks Gentlemen,
Yes, transformers!   I had planned to use an Edcor S2M passive transformer device to sum and balance the signal at the source.   https://www.edcorusa.com/s2m.  I have one left over from another job where I bought two and only needed one.  It worked great there.
@ Mike Caldwell - I've used a lot of RDL's little problem solvers before.  I've put a dozen or so of their D-J series Decora input modules in various jobs, including this one.  In fact, the unbalanced source I'm working with is the 'Pre-Amp Out' of their HD-MA35U utility amplifier.  I think I'll get a TX-A2 to use at the receiver.  https://www.rdlnet.com/product.php?page=504
Thinking more, the CMRR behavior of a transformer at the receiving end is obvious.  Duh.
Steve M Smith
  • Isle of Wight - England
« Reply #9 on: November 05, 2020, 03:17:13 AM »
Yes. those Peavey transformers are actually qhite good. I have used them in a few things.
Steve.
Page created in 0.057 seconds with 23 queries.
