Author Topic: Help figuring out these EAW specs please?  (Read 303 times)
Mike Henderson
« on: October 22, 2020, 09:30:00 am »
Guys, I am seeing different formats in the specs listings fo these two speakers:
https://docs.google.com/viewer?url=https%3A%2F%2Feaw.com%2Fwp-admin%2Fadmin-ajax.php%3Fjuwpfisadmin%3Dfalse%26action%3Dwpfd%26task%3Dfile.download%26wpfd_category_id%3D549%26wpfd_file_id%3Did%3AqAO8a3rMcVAAAAAAAAAc_Q%26token%3D%26preview%3D1&embedded=true
and
https://docs.google.com/viewer?url=https%3A%2F%2Feaw.com%2Fwp-admin%2Fadmin-ajax.php%3Fjuwpfisadmin%3Dfalse%26action%3Dwpfd%26task%3Dfile.download%26wpfd_category_id%3D280%26wpfd_file_id%3Did%3AqAO8a3rMcVAAAAAAAAAYTw%26token%3D%26preview%3D1&embedded=true
As you can see the 300e's specs show in a nutshell it is 500 watts but 300i's specs have split of the wattages of each speaker in it's 3 way configuration. Anyone tell me simply what is the continuous and peak wattage ratings and also the SPL ratings is please?
Brian Bolly
  • Baltimore/Amsterdam
Re: Help figuring out these EAW specs please?
« Reply #1 on: October 22, 2020, 09:58:50 am »
It's right there in the spec sheets.
KF300e page 2:
In biamped mode, the low frequency section produce a Sound Pressure Level (SPL) of 99 dB SPL on axis at 1 meter with a power input of 1 Watt, and shall be capable of producing a peak output of 132.8 SPL on axis at 1 meter. It shall handle 600 Watts of amplifier power (AES Standard) and shall have a nominal impedance of 6 Ohms.
In addition, the mid/high section in biamped mode shall produce a Sound Pressure Level (SPL) of 104 dB SPL on axis at 1 meter with a power input of 1 Watt, and shall be capable of producing a peak output of 134.8 SPL on axis at 1 meter. The mid/high section in biamped mode shall handle 300 Watts of amplifier power (AES Standard) and shall have a nominal impedance of 6 Ohms.
Translation: 600 watts LF; 300 Watts MF/HF - 6 ohm loads for each.
KF300i page 1:
Frequency Response of 65 Hz - 18k Hz 3 dB;
Axial Sensitivity (1 W @ 1 m) of 101 dB SPL (LF); 106 dB SPL (MF & HF);
100 hour sine wave Power Handling of 250 Watts (65 Hz to 300Hz), 100 Watts (300 Hz to 18 kHz);
If you look at page 45 or 47 of the KF300i spec sheet, you can see they're putting the electronic crossover between LF and MF/HF right around 475 Hz or so.
Translation: 500 watts LF and 200 watts MF/HF
The KF300i is not a passive box - it is biamp only.  The KF300ix shows an input plate with a passive option switch, but I don't see on the spec sheet where it discusses the passive power rating - I would suspect in the 400-500 watts range.
« Last Edit: October 22, 2020, 10:01:21 am by Brian Bolly »
Mike Henderson
« Reply #2 on: October 22, 2020, 10:39:53 am »
KF300e page 2:
GREAT Brian, thank you very much for breaking this down for me!
KF300i page 1:
Page created in 0.039 seconds with 22 queries.
