Author Topic: Behringer X32 scene load  (Read 861 times)
Robert Lofgren
Re: Behringer X32 scene load
« Reply #10 on: October 06, 2020, 02:07:46 am »
You can go with either. You can even send that command using midi, should you want to.
That commandline can be edited manually into a snippet (and possibly a scene as well) so when you load that snippet/scene it will change the layer for you. Scenes/snipoets are text based.
Wow! I didn't know this mixer would interact with command lines over ethernet. Can this be accomplished if the X32 is plugged into a router, or would the laptop connect directly to the mixer via ethernet?
P.S. I was really hoping it would just be a matter of toggling a setting within the mixer, but that doesn't seem to be the case.
Page created in 0.022 seconds with 25 queries.
