Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Console Connectivity Solutions
Stream Deck, TeamViewer, and QLab
<< < (2/2)
Andrew Broughton:
--- Quote from: Benjamin Krumholz on August 26, 2020, 10:11:32 PM ---So, i went out and bought a StreamDeck Mini and answered my own question.
It works pretty well so far.
At first I set up the control software on the remote computer that is running Qlab and the StreamDeck would not connect.
After that, I installed the control software on my local computer.. It connected. I mad a few buttons for simple Hotkey key strokes that Qlab has.. Go is Spacebar, Up is Up down is Down, Anything that has a Hotkey in the program you can program a key for on the StreamDeck. Then in the settings of the control software you can select a default program for the commands to be used. In this case, TeamViewer.
Boom it works! As long I am focused in to the correct software on the remote computer. The commands from the StreamDeck pass from my local computer to the remote machine.. The only problem now is that I have to run multiple TeamViewer machines at once.. I'm going to need a dedicated computer for that remote session only.. That way when i click back into my console remote session i don't go issuing key strokes for that software.
--- End quote ---
MUCH easier with Companion. No need for the software to be "focused" and no need for TeamViewer. If you don't want a dedicated computer just for the SD you can use an RPI. Definitely no need for TV on a local network, and optional over the internet.
It's all doable, just some steps to go through if you're doing this for the first time. I probably should make a video on how to do all this when I get some time. Too many other pressing things atm! (Sorry, Brian!)
Navigation
[0] Message Index
[*] Previous page
Go to full version
