Author Topic: Soundcraft Ui16 power up mode  (Read 635 times)
Jim Boczek
« on: August 11, 2020, 09:32:32 pm »
I am new to the digital mixer world and am looking at a Soundcraft Ui16 for our church. I am wondering how the mixer handles powering off and back on. Does it come up with the last settings or is everything at some startup point. There won't always be someone who knows how to setup the mixer at the services so it needs to remember the last setup, or at least one that will work with minimal changes.
Mike Caldwell
  • Covington, Ohio
Re: Soundcraft Ui16 power up mode
« Reply #1 on: August 11, 2020, 10:08:33 pm »
Yes it will power up with settings as they were when turned off.
Pre sets/scenes can be saved for different events and services and recalled as needed.
As with most small digital box mixers the built in wifi is not all that great, you should plan on setting it up with an external wifi router and turning off the internal wifi.
« Last Edit: August 11, 2020, 10:13:14 pm by Mike Caldwell »
Jim Boczek
« Reply #2 on: August 12, 2020, 08:24:55 am »
Thanks Mike, That make me feel better about using it. We already have wifi there since we have been livestreaming our services so we will keep that in mind.
Jim
Chrysander 'C.R.' Young
  • North Central FL
« Reply #3 on: August 12, 2020, 08:58:24 am »
Jim
I suggest that your sound system controls be a separate network that has a unique SSID, is secured using WPA2, and have a wired backup.
Dave Pluke
    • BIGG GRIN Productions
« Reply #4 on: August 12, 2020, 06:50:14 pm »
When doing setups for installations with the Ui series, I save a couple of snapshots with names that should be plainly understood by anyone accessing the GUI.  Then, in case anything does get messed up, the snapshot can quickly be pulled from the dropdown menu.
Dave
Mike Caldwell
  • Covington, Ohio
« Reply #5 on: August 12, 2020, 11:39:25 pm »
Let me to that with a hidden SSID.
Page created in 0.12 seconds with 22 queries.
