Thank you! I will look into it more and see what I can adjust. I appreciate the help.
Also on the XR16 turn off the internal WIFI broadcast.
I have my systems set up more or less like all the suggestions here.
As mentioned get a WIFI scanner app so you can see what channels are in use and set you router accordingly, I check every location I set up in.
Last I checked they were only available for Andriod though. That works for me I mix with iPads but my personal tablet is Android.
On 2.4ghz there are only three channels that do not overlap with each other, 1, 6 and 11. Guess what three channels are used more often than not!
5ghz channels do not overlap one another.
